When Varonis field CTO Brian Vecci quipped that “every copilot pilot gets stuck in pilot” at a Fortune Brainstorm Tech panel, the laughter in the room masked a sharper truth: organizations desperate to extract business value from generative AI are repeatedly hitting the same barrier — data security and governance. That one-liner captured why so many promising trials stall: without a rigorous, practical approach to data protection and operational controls, pilots never graduate to sustained, measurable deployments.
A futuristic holographic security dashboard with shield icons, a digital human, and data panels.Background​
Enterprises launched a deluge of Copilot and agent pilots in 2023–2025, chasing productivity gains and automation. Early wins and customer stories helped accelerate trials, but as pilots widened their scope they also exposed systemic weaknesses: messy permissions, orphaned data, inconsistent labeling, and unclear vendor commitments about data use. These are not abstract compliance headaches — they’re immediate, trackable risks that can derail projects or trigger regulatory fallout. Microsoft, security vendors, and enterprise customers have responded with a mix of product controls, third‑party tooling, and new governance models designed to keep pilots safe while letting experimentation continue.
Why so many Copilot pilots stall​
1) Unknown and overexposed data​
Most Copilot-style assistants surface only what a user is permitted to see — but many organizations don’t know what users are permitted to see. Files live in forgotten folders, SharePoint sites are open by default, and guest or inherited permissions create surprises when Copilot is turned on. When pilots begin returning sensitive items — payroll data, source code, M&A documents — trust evaporates and IT often pulls the plug. This dynamic is precisely what Vecci described: the technology quickly reveals the gaps that existed long before the AI arrived.
2) Governance and contractual ambiguity​
Large enterprises and regulated institutions demand clarity on data handling: where tenant data lives, whether it can be used for model training, and what telemetry is recorded for auditing. Those questions are solvable, but not instantly — they require contractual commitments, technical isolation, and verification. Executive teams frequently stop pilots to renegotiate terms or insist on detailed logging and non‑training guarantees before expanding usage. Microsoft and other major vendors now publish explicit controls and privacy guidance, but confirming those guarantees in contracts and operational tests remains nontrivial.
3) Organizational friction and culture​
Overly tight restrictions can suffocate experimentation; overly loose policies create risk. Leaders such as Cargill’s Keith Na emphasize the need for a culture of curiosity — safe spaces where engineers can break, test, and learn — while keeping guardrails intact. The tension between preserving experimentation and preventing data loss shows up in real deployment decisions: who gets access, what use cases are allowed, and how outputs are validated. The organizations that move beyond pilot mode find ways to combine both impulses.
4) Measurement and ROI gaps​
Pilots that don’t define measurable outcomes — time savings, error reduction, cycle time — are vulnerable. Without clear, CFO‑grade metrics, pilots can be labeled “failed” even when they show promise in qualitative areas. Poor pilot design, absent integration into workflows, and inadequate upskilling are recurring root causes of stalled programs. Independent analysts have debated the headline figures about pilot failure rates, underscoring that the design of the pilot matters as much as the underlying model. (The exact failure-rate statistics are contested and depend on methodology; treat sweeping percentages with caution.
What vendors (and Microsoft specifically) now offer to bridge the gap​
Modern enterprise Copilot deployments rest on three pillars: data protection, identity/access controls, and auditability. Microsoft’s public documentation and product releases illustrate concrete features that organizations can leverage to lower the pilot‑to‑production friction.
  • Microsoft Purview and sensitivity labels: Purview can discover overshared content, apply label‑based permissions, and enforce label inheritance so that Copilot honors access restrictions and encryption tied to sensitivity labels. This prevents Copilot from returning encrypted content unless the caller has the requisite extract/view rights.
  • Tenant isolation and non‑training commitments: Microsoft states that customer tenant data is not used to train upstream foundation models unless explicit agreement permits that, and that Copilot operates within tenant boundaries to prevent cross‑tenant leakage. Organizations should validate these claims in contracts and technical testing.
  • Zero Trust guidance for Copilot: Microsoft publishes a Zero Trust checklist for Copilot deployments — covering data protection, identity, device posture, app protection, and monitoring — which organizations should adapt into their rollout playbooks.
  • Agent controls in Copilot Studio: For low‑code agents, Purview and Copilot Studio now provide data controls and RBAC to bind agents to specific data scopes and apply label inheritance. These features shorten the compliance runway for safely building domain agents.
These vendor features substantially reduce the blast radius of Copilot pilots — but they are not a silver bullet. Organizations still need disciplined processes and tooling to make these controls effective.
Hard verification: what leaders must check before scaling​
Any claim in vendor marketing must be verified operationally. Before expanding a Copilot pilot, confirm the following with both technical proofs and contractual language:
  • Tenant residency and isolation — verify data never leaves your tenant boundaries for the tested configuration.
  • Non‑training guarantees — obtain explicit contractual commitments stating whether or not your prompts or files will be used to update vendor models.
  • Label inheritance and DLP enforcement — run synthetic prompts against labeled content and confirm outputs inherit labels and that DLP policies block unauthorized disclosure.
  • Audit logs and immutable telemetry — ensure every prompt/response is logged in a way that supports eDiscovery and forensic review.
  • Least privilege and RBAC — verify that agents and users access only the data necessary for the use case.
Run these tests in a staged environment and retain signed contractual commitments; the combination of technical proof and legal assurance is what persuades risk‑sensitive stakeholders to proceed.
A practical, repeatable playbook for moving pilots to production​
Below is a condensed, actionable playbook for CIOs and CISOs who want to scale Copilot pilots while keeping data safe.
Phase 0 — Before you pilot​
  • Inventory and map: discover all data stores (SharePoint, OneDrive, file servers, enterprise apps) and map sensitivity.
  • Classify: apply sensitivity labels and auto‑labeling policies where possible.
  • Harden identity: enforce MFA, conditional access, and device posture for pilot participants.
Phase 1 — Pilot design​
  • Choose constrained, measurable use cases (e.g., invoice triage, meeting summarization, HR FAQ) that minimize high‑sensitivity exposure.
  • Define success metrics and telemetry to collect (time saved, error rate, escalation frequency).
  • Create sandboxed tenant(s) or private environments for agent development. Use Copilot Studio with limited data scopes.
Phase 2 — Technical controls​
  • Enforce Purview label‑based permissions and DLP.
  • Implement role‑based access for agents and service principals.
  • Activate logging and retention policies for prompts/responses.
  • Consider customer‑managed keys (CMK) for critical data.
Phase 3 — Operational governance​
  • Human‑in‑the‑loop validation for any output used to make decisions.
  • Red team and privacy testing — attempt to exfiltrate labeled data via crafted prompts.
  • Incident playbook: exercises for AI-specific incidents (prompt leakage, hallucination with PII).
Phase 4 — Scale safely​
  • Publish an expansion plan tied to metrics and independent validation.
  • Train end users and create “Copilot champions” to model safe behaviors.
  • Monitor cost, usage patterns, and environmental impact (compute/carbon).
These steps turn best practices into an operational cadence: pilot, measure, fix governance gaps, and expand.
Culture: the other half of the equation​
Technical controls alone won’t scale pilots. Leaders quoted at the Fortune Brainstorm Tech panel urged combining strong guardrails with a culture of curiosity so engineers can innovate without causing damage. Successful organizations create safe experimentation zones — isolated tenants or sandboxes where teams can iterate quickly, fail cheaply, and share lessons. Embedding engineers directly into product teams, as Cargill has done, reduces friction and raises morale while still preserving oversight. Training, internal certifications, and visible executive sponsorship accelerate safe adoption.
  • What works in practice: short sprints with named owners, dedicated funding for adoption activities (training, playbooks, office hours), and metrics reporting to the CFO.
  • What fails: overcentralization that blocks every experiment, or laissez‑faire approaches that treat Copilot like an ordinary SaaS product without special governance.
Strengths and the near‑term upside​
  • Productivity gains: In targeted workflows, Copilot and agents routinely reduce manual effort, speed information discovery, and automate repeatable tasks. Microsoft and customer case studies report substantial time savings when agents are integrated into processes.
  • Faster knowledge access: Copilot can summarize, extract, and surface context from dispersed corporate data — a direct productivity multiplier when data is properly curated.
  • Platformization of workflows: Copilot Studio and agent frameworks let organizations package repeatable knowledge work into reusable agent components, shortening the path from idea to impact.
Risks, trade‑offs, and open questions​
  • Data exfiltration and silent leakage: Even when models respect permissions, misconfigurations and orphaned shares can surface sensitive data. Red‑team testing is essential.
  • Hallucinations and incorrect outputs: AI can invent plausible‑sounding but false information; human validation is required when outputs inform decisions.
  • Vendor lock‑in and contractual opacity: Deep integrations into a single vendor’s stack increase switching costs; negotiate portability and export rights up front.
  • Operational cost and carbon footprints: Running large‑scale agent workloads has measurable compute costs and emissions; track usage and optimize agents for efficiency.
  • Contested metrics about pilot failure rates: Headlines citing extreme failure percentages (e.g., “95% fail”) are often contested; methodologies and definitions vary. Treat broad statistics as conversation starters, not final judgments.
Where claims are not independently verifiable — for example, any specific percentage on pilot failure drawn from one meta‑analysis — organizations should treat them as directional and perform their own audits rather than rely solely on press summaries.
Short checklist for immediate action (CIO / CISO)​
  • Run a pre‑deployment oversharing assessment using Purview or equivalent to find risky SharePoint/OneDrive sites.
  • Apply sensitivity labels and enforce label inheritance for agent outputs.
  • Secure pilot participants via conditional access and device posture.
  • Require human validation on any Copilot output used for decisions or customer communication.
  • Contractually verify non‑training and tenant isolation commitments; run independent tests.
Case studies: pilots that moved to production (what they did right)​
  • Large industrial customer (example): Focused on a high‑volume, low‑risk problem (freight invoice processing), built two cooperating agents (an autonomous extractor plus a promptable Copilot assistant), and measured immediate monetary savings — then scaled. Their secret: narrow initial scope, strong data engineering, and a human‑in‑the‑loop escalation path.
  • Microsoft’s own rollout lessons: Early Microsoft internal deployments emphasized labeling, Purview enforcement, and a broad training program to create Copilot “champions” — a combination of product controls and cultural investment. These show the power of pairing governance with mass upskilling.
These success patterns repeat: start small with measurable KPIs, protect data aggressively, and invest in the human processes that sustain adoption.
Conclusion — balance, not binary choices​
Brian Vecci’s quip that “every copilot pilot gets stuck in pilot” is a useful provocation: pilots do stall, but they don’t have to. The path forward requires balancing two imperatives at once: protect the data and preserve the space to experiment. Technical controls from vendors like Microsoft — Purview, label inheritance, tenant isolation, and Zero Trust guidance — materially reduce risk when combined with rigorous testing, contractual clarity, and cultural changes that enable engineers to innovate safely. Leaders must treat pilot scaling as a program of technical verification plus organizational change: inventory and classify, design measurable pilots, bake governance into the tooling, and create safe sandboxes for learning.
Finally, remain skeptical of sweeping statistics about pilot success or failure: methodologies differ and headlines oversimplify nuance. The pragmatic course is clear — validate vendor claims, measure pilot outcomes against business metrics, and keep guardrails that allow innovation to flourish without exposing the company to unnecessary legal, compliance, or reputational risk.
Source: Fortune AI pilots keep stalling on data fears. The fix? A culture of curiosity. | Fortune
