When striving for optimal performance on a Windows 11 PC, it's all too easy to get lost in the eye candy and extras that Microsoft enables by default. Out of the box, the latest version of Windows often looks beautiful, but many users notice a tangible lag in responsiveness—even on brand-new hardware. For those who value speed and efficiency above visual flourishes, several settings and utilities can transform Windows 11 from a pretty face to a productivity powerhouse. Drawing on expert-proven tweaks and desktop-tested strategies, this feature explores practical, safe, and verified methods to make your PC faster today. Each tip has been cross-checked for accuracy and includes critical nuance to ensure you know both the benefits and any potential downsides these adjustments might bring.
A futuristic blue abstract design overlays a digital cityscape with glowing parallel lines and data interfaces.
Unlocking Speed: 5 Proven Windows 11 Tweaks for a Faster PC​
Why Your PC Feels Sluggish—Even with High-End Specs​
It’s a familiar story: you invest in a powerful new PC or upgrade your existing system, expecting lightning-fast load times and seamless multitasking. Yet, as weeks pass, the computer boots more slowly, and everyday actions feel less snappy. The causes are rarely hardware alone. The reality is Windows 11, like earlier iterations, is configured for general-purpose appeal rather than peak performance. Default settings prioritize good looks, compatibility, and background services—which most users never touch but which continue to use valuable resources. To counteract this, experienced Windows users turn to a handful of proven optimizations that emphasize speed.
1. Enable Ultimate Power Mode: Unleash Every Watt​
One hidden gem in Windows 11 is the Ultimate Performance power plan. Originally intended for high-end workstation hardware running Windows 10 Pro for Workstations, Ultimate Performance mode shuns energy-saving algorithms in favor of raw speed. By default, this advanced setting is not visible to most users, but enabling it takes just a minute and can deliver noticeable improvements—especially for power users running multiple productivity apps, virtual machines, video editing suites, or demanding games.
To activate Ultimate Performance mode:
  • Open PowerShell as Administrator.
  • Paste and run:
    powercfg -duplicatescheme e9a42b02-d5df-448d-aa00-03f14749eb61
  • Navigate to Control Panel > Power Options.
    Select the new "Ultimate Performance" plan.
  • Restart your PC to apply the change.
What Does This Actually Do?​
Unlike the Balanced or High Performance modes, Ultimate Performance sets all system hardware—CPU, SSD, GPU, RAM—to prioritize peak output and low latency. It disables many of Windows’ power-saving features, ensuring the processor is always ready to work at full speed. Critics point out that this mode can increase power consumption and may not be suitable for laptops or battery-conscious users. For desktops and plugged-in gaming rigs, however, the trade-off is typically worthwhile.
Critical Analysis​
  • Strengths: Noticeable speed increase for heavy multitasking and demanding workloads. Easy to enable.
  • Potential Risks: Higher electricity usage, increased heat output, and shorter component lifespan if used on portables. Unsuitable for eco-conscious or laptop users.
2. Wintoys: A Swiss Army Knife for Power Users​
Managing performance tweaks piecemeal through Windows’ ever-sprawling Settings app and Control Panel quickly becomes frustrating. Enter Wintoys, a free utility designed to bring the most important system and optimization tools under one roof. With Wintoys, users can access tweaks for startup programs, disk cleanup, privacy, and God Mode—all in a slick interface.
Why Use Wintoys?​
  • Centralizes essential settings that are scattered otherwise.
  • Facilitates quick toggling of performance enhancements without deep digging.
  • Automatically enables God Mode—a special folder exposing dozens of advanced settings—saving users significant time.
Wintoys itself does not directly speed up your computer; however, by exposing all relevant controls in one app, it empowers you to reliably apply optimizations that otherwise might go unchecked.
Download and Safety​
Wintoys is available via the Microsoft Store, reducing risk compared to random .EXE files on the web. Always check for the latest version and read recent reviews to ensure ongoing security and support. Third-party utility developers occasionally change permission structures, so current user feedback is valuable.
Critical Analysis​
  • Strengths: Dramatically increases efficiency for system tweaks; no need to memorize Windows’ hidden paths or registry edits.
  • Risks: Some power user features still require technical knowledge; always back up before making major changes.
3. Disable Startup Apps: Turbocharge Boot Times​
Every Windows user has experienced the creeping lag that comes with too many programs auto-launching at startup. Whether it’s Office, OneDrive, chat clients, or creative suites, each application that starts with Windows eats into system memory and CPU cycles—before you ever open a single file.
The Proven Path: Task Manager​
  • Press Ctrl + Shift + Esc to open Task Manager.
  • Go to the Startup tab.
  • Review all entries—focus especially on those labeled "High impact."
  • Right-click and disable anything non-essential (e.g., Adobe Updater, Spotify, cloud sync tools).
What’s Safe to Disable?​
Ask yourself: “Do I use this app immediately, every time I boot?” For almost all users, it is safe to disable everything. Essential Windows processes will not appear on this list. The only consequence is that applications you do need will take a few seconds longer to start the first time—but your overall boot and idle performance will benefit dramatically.
Related Utilities​
The Wintoys utility also makes managing startup apps easier, providing quick summaries and recommendations. There’s no harm in trying both approaches.
Critical Analysis​
  • Strengths: Immediate, measurable improvement in boot speed and responsiveness; fully reversible.
  • Risks: If you depend on a background sync or update process (e.g. antivirus, OneDrive), make a note to re-enable as needed. But for most users, manual launches suffice.
4. Disable Animation Effects: Performance over Aesthetics​
Windows 11 takes visual polish to new heights, but animations—such as window fades, sliding menus, and transitions—can tax older GPUs or eat up precious resources on resource-constrained hardware. Even with high-end computers, turning off these effects can make the interface feel just a bit snappier.
How to Disable Animations​
  • Open Settings > Accessibility > Visual effects.
  • Turn off "Animation effects."
  • For additional control, access Settings > System > About > Advanced system settings > Performance Options to customize even more visual tweaks.
What’s the Real Benefit?​
While disabling animations won’t turn a budget laptop into a gaming rig, the cumulative effect is a sharper, more responsive feel. Window opening, closing, and switching all occur instantly—delivering performance akin to classic, low-overhead Windows builds.
Critical Analysis​
  • Strengths: Easy to reverse; especially effective on older or integrated-graphics hardware.
  • Risks: Windows will look more basic and lose some of its modern polish. Those who value appearance over speed may prefer to leave some effects intact.
5. Reclaim Drive Space: Keep Windows Lean and Nimble​
One of the least glamorous, yet most crucial, performance tweaks is regular drive maintenance. If your SSD or HDD is more than 70% full, both boot times and everyday tasks will slow dramatically. This is due to how Windows uses free space for caching, paging, and temporary files.
Proven Methods for Cleaning Up​
Built-in Tools​
  • Legacy Disk Cleanup: Still available in every version of Windows 11. Search "Disk Cleanup" in the start menu, select your primary drive (usually C:), and tick options like "Temporary files," "System files," and "Previous Windows installations."
  • Modern Storage Sense: Go to Settings > System > Storage. Wait while Windows tallies reclaimable space, then use "Temporary files" and clear out large non-essential items.
Microsoft PC Manager​
Launched as an official free tool, PC Manager automates deep storage scans and deletion of clutter—including browser caches, update leftovers, and logs. Some users report recovering up to 10GB on a heavily used drive.
Pro Tips​
  • Always double-check your Downloads and Documents folders before removing large files.
  • To maximize speed, consider moving photos, music, and videos to an external drive, keeping the C: partition as slim as possible.
Critical Analysis​
  • Strengths: Significantly improves both boot and app launch times on full drives; regular maintenance reduces the risk of mysterious slowdowns or crashes.
  • Risks: Deleting previous Windows installations eliminates your ability to roll back major updates. Check backup status first.
More Advanced and Optional Tweaks​
Enable Fast Startup​
Windows 11 includes a Fast Startup feature that combines hibernation and shutdown for quicker boots. While it works well for most users, some with unusual hardware or Linux dual-boots report compatibility problems. Always test after enabling to ensure no side effects.
Clear Browser Histories and Caches​
Each browser—Edge, Chrome, Firefox—keeps its own cache of files and sites. Clearing these not only increases privacy but can free gigabytes of space and sometimes resolve page load delays. Look for the “Clear browsing data” option in your browser settings.
Keep Windows Up-to-Date​
Microsoft issues performance fixes, driver updates, and security patches constantly. The most critical round occurs each Patch Tuesday (the second Tuesday of every month). Delays in updating can leave your system vulnerable and, in some cases, slower than necessary. Always install quality updates promptly, but defer untested feature upgrades on mission-critical systems.
(For Gamers) Disable Optional Virtualization Features​
Virtualization, enabled by default on many new systems to support Windows security features and platforms like Windows Subsystem for Linux, can introduce a minor performance hit in games. Disabling features like Hyper-V, Virtual Machine Platform, or Memory Integrity in Windows security settings can sometimes net a few extra frames per second, but do so only if you do not use virtual machines and understand the security implications.
Conclusions: Squeezing the Most Performance out of Windows 11​
For those who value speed and productivity, Windows 11 offers a wealth of underutilized optimizations beyond the flashy UI. By enabling Ultimate Performance mode, centralizing tweaks with Wintoys, neutering startup apps, ditching UI animations, and keeping your storage trim, you can transform Windows into a responsive, focused workhorse. Just as critically, regular maintenance and staying updated will ensure these gains are preserved over the long term. As with any OS tuning, make changes methodically, test the effects, and back up essentials before major adjustments. With these strategies, both casual users and seasoned power users alike can reclaim the fast, stable Windows experience promised—but not always delivered—by default settings.
Source: XDA https://www.xda-developers.com/proven-windows-11-tweaks-that-speed-up-my-pc/
