marglim
Well-Known Member
Hi. I have a VAIO laptop VGN CS13G series. A few months ago, the darn thing stopped working. Turns out I had a busted cooling fan and a fried hard disk. I had the broken parts replaced and had the tech install Windows 7 (pre-installed OS was Vista Home Basic). Problem is, I don't have the original drivers and software and my recovery discs are missing. I tried downloading them on the sony website. I'm just not sure if I'm doing it right. I downloaded the ones for Vista. Everything for 7 were "upgrades" or "patches" so I thought I would need them first before I could upgrade them to the ones for 7. Naturally, some of them didn't work. I tried the Automatic Upgrader option but it said I needed the VAIO Updater version 4.0. So I tried downloading that one, too. Nothing happened. Do I need to download all the drivers manually one by one then? Please help. :c Thanks so much!
It sounds like you are facing difficulties in obtaining the necessary drivers and software for your VAIO laptop after reinstalling Windows 7. Here's a step-by-step guide on how you can approach this situation to ensure that you have all the required drivers and software:
Steps to Obtain Drivers for Your VAIO Laptop:​
  1. Identify Your Laptop's Model:
    • Verify the exact model of your VAIO laptop (VGN-CS13G in your case) as drivers and software are specific to each model.
    []Visit Sony's Support Website:
    • Go to Sony's official support website for VAIO laptops and navigate to the support section.
    ]Locate Drivers for Windows 7:
    • Look for drivers and software specifically...
    • Look for drivers and software specifically designed for Windows 7 compatible with your VAIO model.
    • Ensure that you are downloading the drivers labeled for Windows 7, not the Vista drivers.
    []Manual Driver Downloads:
    • If you couldn't find an all-in-one package for your model, you might need to download the drivers manually.
    • Look for essential drivers like graphics, sound, wireless, chipset, etc., and download them one by one.
    ]Install VAIO Updater:
    • The VAIO Updater tool is essential for keeping your VAIO laptop up to date. Make sure to download and install version 4.0 to proceed with updates.
    []Install Drivers in Order:
    • Start with essential drivers like chipset, graphics, and sound before moving on to additional software and utilities.
    ]Check Device Manager:
    • After installing the drivers, verify if any devices are still missing drivers by checking the Device Manager in Windows.
      Additional Tips:​
    • Create a System Restore Point:
    • Before making any changes or installing drivers, create a system restore point to revert back in case of any issues.
    • Check for BIOS Updates:
    • It's also a good idea to check for BIOS updates for your VAIO laptop, as these updates can improve system stability and compatibility.
    • Consider Driver Update Software:
    • If manually downloading drivers seems overwhelming, you can use driver update software tools that scan your system and automatically download the required drivers. By following these steps and ensuring that you download the correct drivers and software for your specific VAIO model and Windows 7, you should be able to get your laptop up and running smoothly again. Let me know if you need any further assistance or encounter any issues during this process!
