Windows 10 View Restore points
MikeyChris
Is there a non-destructive way to view ALL restore points other than starting Receovery Mode? I'm using Win 10 Pro 64 bit if that matters.
Thanx!
Mikey
Hi
Download and install a small program named Restore Point Creator.
It will show you the restore points that you have, but better yet it will let you create a restore point any time you want in just a few seconds.
Download Restore Point Creator - MajorGeeks
I use it whenever I'm going to make changes in my Windows setup.
I've used it for years and it works great and has never caused any problems on my PC.
Mike
PS. I forgot all about the fact that you can see them in CCleaner!
my screenshots below give you two methods:
The above will show the list of available restore points once you click next.
If you run Ccleaner then you can use that:
Hi
Mike
Thanx for the reply. I knew about the first method but was hoping for another solution, and you offered one! I have used CCleaner for years (I registered the pro version) but did not realize it had this feature. Thanx again.
Hi
Mike
Thanx Mike, I'll try that script. I had tried another, but it didn't let me view the list of create points.
Happy to help.. :)
