Windows 7 VOLUME HELP
casi
hello everyone. i will get strait to the point:my volume is going up and down by itself nomatter if i am using winamp or streaming.any solutions will be appriciated,i would add that my audio is controllet by srs hd audio lab(audio plugin)kind regards casi:(
Hi Casi,
Casi if you check my screenshot you'll see where to change settings which should fix this issue:
Link Removed due to 404 Error
Top Bottom
