VS 2008 and VSS 2005
Greetings,
I've been unable to get VS2008 and VSS 2005 to play nice together on Windows 7. They worked fine on XP. I have downloaded and installed the CTP that is supposed to enable this.
VSS works fine on its own as does VS2008. I just can't access the source control features from within studio.
Has anyone gotten this to work?
Thanks!
BTW - this is Windows 7 Enterprise, 32-bit.
Working, sort of
It is working after a fashion. I cannot open projects directly from VSS which I used to be able to do. If I do a checkout using VSS client and then edit with VS2K8, I get VSS features.
Very clunky. I am most likely going to move us to Subversion (using Visual SVN Server) and a VS Plug-in. That works quite well.
