Windows 8 Whats wrong with my ip address and how do i fix it??
Ruben Aahseim
Hi my IP-address keep showing "fe80::7517:d7d1:2de4:32da" and with this address i can't access to and i don't know how to fix it, please help me!
An image from 'Whats wrong with my ip address and how do i fix it??'. Command prompt showing network adapter details, including IPv6 and IPv4 addresses.
It is unlikely that you are using IPv6 at the moment so you should just ignore it - in fact you can disable IPv6 for now - unless you know that you are one of the few who currently need it.
Shotocan
Well-Known Member
It's a ipv6 ip address. ipv6 will eventualy replace ipv4 which is the ip address you are used to seeing. Ipv6 will give us many more ip addresses. As we are pritty much out of ipv4 address' s.
Sent from my GT-N7100 using WindowsForum mobile app
patcooke
Microsoft MVP
Microsoft MVP
Shotocan
Well-Known Member
I am not sure I would disable it. It say's "link local" might be the router is working ipv6. And disabling it could cause problems.
patcooke
Microsoft MVP
Microsoft MVP
"It say's "link local" might be the router is working ipv6." - it will be an autofiguration address.
