first of all thanks for fast replay .. but after i clicked on the Speaker icon i did not find Mic or Record button or option which allow me to add it to Speaker icon on the Taskbar
and here is the result
and here is when i click on Speaker Icon on Taskbar then click on Mixer Link Removed
As i know i can enable or disable your microphone through Control Panel -> Sound. Select the recording tab, and enable/disable at will.
but what i'm looking and asking for is how can i add a separate taskbar icon for microphone control , to mute (disable) and unmute (enable) Mic like it was in Windows XP
