awbarnett
Active Member
I am building 2 computers exactly the same.
I have purchased 2 copies of Windows 7 pro
I have installed one copy Windows 7 Pro and all of my programs and data files on the first computer and activated it.
After I get the second computer built I would like to avoid re-installing everything on the second computer.
Somewhere I saw where I could change the Product Key Code.
My question is:
Can I simply put a copy of the hard drive from the first computer into the second computer, then change the product key code to that of my second copy windows 7 pro so that I can activate it too.
Thanks, awbarnett
patcooke
Microsoft MVP
Microsoft MVP
Yes, after setup goto control panel, system, change product key.
awbarnett
Active Member
Hello patcooke:
Thank you very much for your response.
awbarnett
