Win 7 - Sony VAIO SZ330 display
My Windows 7 Home Premium install on a Sony VAIO SZ330 laptop went fine, EXCEPT,the display will not show as full screen. Device Manager shows the display adapter as "Standard VGA Graphics Adaptor." with max of 1024*768.
Display: 13.3 screen; 1280*800; 16:10 LCD,
VIdeo: NVIDIA GeForce Go 7400 128mb
Any suggestions? Thanks.
Saltgrass
Can you get a new driver from Sony?
Thanks. Sony does not support WIndows 7 for that model .... but .... I downloaded their Vista Driver for the graphics display and (so far) it WORKS. Thanks for the advice.
pls help
i also have a viao (vgn-fz348) i cant use the upgrade option coz its saying i should be running sp1
i did clean install and just like what you said its using the standard graphics card
i download drivers fron sony but it wont work
how did you do it?
did you do upgrade or clean install
where did you get the updated graphics driver
thanks
