Nomy
I have dimension 5150 Sound Card and After Driver Installation I cant get sound!
When i troubleshoot it , error about service of Windows Audio appeared but i tried to Start this service but cant start it due to following Error
Windows Can not Start the Windows Audio Service On Local Computer
Error 1079 : The Account Specified For This Service is different from the account specified for other service running in the same process !
Even Driver are Installed at Device Manager! But Still No Sound! Immediatly Help pls OtherWise window is Perfect !
Hi
I found this on another forum, the second one worked for the poster...
Open an elevated (Admin) command prompt. Copy/paste this command then press enter:
net start audiosrv
If that doesn't work, try this.
1. Open cmd.exe with Administrator rights
2. Paste in:
"secedit /configure /cfg %windir%\inf\defltbase.inf /db defltbase.sdb /verbose"
(probably without the quotes but if that doesn't work try it with the quotes).
3. Restart your computer when the process completes
Hi
Try uninstalling your audio device in Device Manager, then reboot.
Windows will redetect and reinstall the device.
It might do it right, this time.
Anyway it will get you back to the default drivers and settings.
Mike
Well I Tried that too it doesnt Work for me! :( Kindly help i dont want to go back for xp
Hi
Check this out...
no sound (audio service will not start, error 1079) - Microsoft Community
This seems to be a fairly common problem.
I see a lot of posts about this.
Mike
And Again no response from it :'( help me plS! ._. any other solution plS!?
Hi
net start audiosrv
2. Paste in:
