The user is seeking guidance on setting up a Windows-based captive portal server to authenticate guest WiFi users via Google or Facebook, and to recognize devices by MAC address across multiple routers. Several responses suggest using NAC solutions like PacketFence, which is Linux-based, but the original poster clarifies they prefer a Windows-compatible, installable executable. Overall, the discussion highlights a challenge in finding free Windows-compatible NAC or captive portal solutions suited to the user's requirements.
hiranuk
Hi
I was wondering if anyone could help. I would like to configure a "windows wireless captive portal server" it does not have to be on Windows server 2012 it can be any windows server. i'll explain what i am trying to achieve.
I am having a Guest Wifi on multiple Draytek Routers. The routers have an option to enter a "captive portal server IP". The idea is that when a user connects to the Guest WiFi they will have a splash screen which will ask then to login via "Google mail" or "facebook", (This splash screen is configured on the Draytek Router). Then once the user enters their google login or facebook login their device MAC address is to be passed over to the Windows server and kept. This is so if that same user was to connect to another different Draytek router and connect to its guest WiFi they will not need to login using google or facebook as that server will recognise that device by its MAC address.
I am a Network specialist and have no experience in configure servers. Does anyone have a step by step guide on how i could configure this server?
Thanks in advance.
There are a lot of products. I think PacketFence is a free NAC with a captive portal feature.
If it's a Windows server it won't be really any different than a Windows desktop then install your NAC software. If you use PacketFence it will be a Linux server. Server setup guides are a dime a dozen on the Internet. Ubuntu is literally a handful of prompts to follow and it's up and running.
Neemobeer
Windows Forum Team
hiranuk
Thread Author #3
Thanks but im looking for something Windows. And exe or something that i can install and then play around configuring.
Neemobeer
Windows Forum Team
Don't know of any free NAC servers that will run on Windows
