The thread focuses on reducing visual clutter on Windows 11 by using taskbar overflow for managing many open windows and customizing system tray (notification area) icons so fewer run-in-the-background icons remain visible. The main questions/answers cover how to enable/locate these controls (including version differences from Windows 10), what to do if options aren’t visible (update Windows, restart Explorer), and how to stop recurring tray icons by disabling unnecessary startup apps (not just hiding tray shortcuts). Overall sentiment is helpful and beginner-friendly, with the guidance framed as reversible and low effort, though it notes that behavior can vary by Windows build and apps can force tray icons to appear.
Enable and Use Windows 11's Taskbar Overflow + System Tray Settings to Reduce Clutter​
Difficulty: Beginner | Time Required: 10 minutes
Windows 11 can get visually “busy” fast—especially if you keep lots of apps open and have a handful of background tools running in the system tray (notification area). The good news: Windows 11 includes Taskbar overflow (so extra open apps don’t crush your taskbar) and System tray controls (so you can choose which icons show all the time).
This walkthrough shows how to turn on and use these features to keep your taskbar clean, readable, and easier to manage—without uninstalling anything.
Prerequisites​
Quick walkthrough
  • Windows 11 (recommended: 22H2 or newer).
    Taskbar overflow is a Windows 11 feature and is most consistently available in Windows 11 22H2/23H2/24H2.
  • A few apps pinned/open (so you can actually see overflow behavior).
  • No admin rights required for most steps.
Windows 10 note: Windows 10 manages “overflow” differently (taskbar buttons can shrink, combine, and you’ll use “Taskbar buttons” settings). The specific Windows 11 Taskbar overflow behavior described here is not the same as Windows 10.
Step-by-step: Enable and use Taskbar Overflow (open apps area)​
Taskbar overflow helps when you have many open windows. Instead of squeezing icons smaller and smaller, Windows 11 will place extra app buttons into an overflow menu (a “more” area at the end of the taskbar).
1) Confirm you’re on Windows 11 and check your version​
The About Windows dialog showing Windows 11 version and OS build information.
  • Press Win + R.
  • Type winver and press Enter.
  • Note your Windows 11 version (for example, 23H2).
Why this matters: If you’re on an older Windows 11 build and don’t see the same options/behavior, updating often resolves it.
2) Make sure the taskbar has enough room to demonstrate overflow​
You’ll usually see overflow once you open enough apps/windows.
  • Open several apps (for example: Edge, File Explorer, Settings, Notepad, Photos).
  • If needed, open additional windows of the same app (multiple Explorer windows, multiple Edge windows, etc.).
3) Use the Taskbar overflow menu​
  • Look at the right end of your taskbar (near the system tray area).
  • When the taskbar gets crowded, Windows 11 will show an overflow indicator (a “more”/additional apps area).
  • Click it to reveal extra open app buttons.
  • Click any app in the overflow list to switch to it.
What you can do from overflow
  • Switch to an app you can’t currently see on the main taskbar row.
  • Close a window/app (often by right-clicking its taskbar entry and choosing Close window, depending on the app and your build).
  • Keep your taskbar readable without manually closing apps.
Note: The exact overflow icon and right‑click options can vary slightly by Windows 11 version and updates.
Step-by-step: Reduce system tray clutter (notification area)​
The “system tray” (right side of the taskbar) is where background apps place icons (cloud sync, GPU tools, chat apps, launchers, etc.). Windows 11 lets you decide which icons appear directly on the taskbar versus tucked behind the hidden icons menu.
4) Open Taskbar settings​
Windows 11 Settings open to the Taskbar page with taskbar and tray options.
  • Right-click an empty spot on the taskbar.
  • Click Taskbar settings.
You’ll land in: Settings → Personalization → Taskbar
5) Control which icons appear in the system tray​
Depending on your Windows 11 version, you’ll see wording similar to:
  • Other system tray icons
  • Taskbar corner overflow
  • System tray icons / Notification area icons
Do this:
  • In Taskbar settings, expand Taskbar corner overflow (or Other system tray icons).
  • You’ll see a list of apps that can show icons.
  • Toggle On for icons you want always visible on the taskbar.
  • Toggle Off for icons you’re fine keeping in the hidden icons menu.
Recommendation (beginner-friendly):
  • Keep security/backup icons visible (e.g., antivirus, backup status).
  • Keep network/VPN icons visible if you use them often.
  • Hide “nice-to-have” launchers/updaters you rarely click.
Tip: If you’re not sure what an icon is, leave it visible temporarily until you confirm it’s safe/expected.
6) Configure Taskbar corner icons (system controls)​
Still in Taskbar settings, look for Taskbar corner icons and choose what appears directly (options vary by device):
  • Expand Taskbar corner icons.
  • Toggle on/off items like:
  • Pen menu (if you have a pen-enabled device)
  • Touch keyboard
  • Virtual touchpad
This can free space and reduce visual noise—especially on smaller screens.
7) Use the hidden icons menu effectively​
  • On the taskbar, click the hidden icons button (typically a small caret/arrow like ^).
  • Review the icons there.
  • If something is constantly running that you don’t need:
  • Open that app and look for a “Start with Windows” option, or
  • Manage it via Startup Apps (next step).
Warning: Hiding an icon doesn’t stop the program from running. It only hides its shortcut in the tray.
Step-by-step: Stop unnecessary tray apps from starting automatically (optional but useful)​
If your tray fills up right after boot, the real cause is usually Startup apps.
8) Disable unnecessary startup apps​
Task Manager on the Startup apps page with startup programs and disable controls.
  • Press Ctrl + Shift + Esc to open Task Manager.
  • Click Startup apps (Windows 11) or Startup tab (older layouts).
  • For apps you don’t need at login, right-click → Disable.
Alternatively:
  • Go to Settings → Apps → Startup.
  • Toggle Off what you don’t want launching automatically.
Tip: Disable only what you recognize. Keep drivers, security software, and critical hardware utilities enabled unless you’re sure.
Tips, notes, and troubleshooting​
Tip: Keep taskbar clutter low with smart pinning​
  • Pin only your “daily drivers” (browser, file manager, chat, work apps).
  • Unpin rarely used apps to keep the main taskbar focused.
Note: Overflow vs. “Combine taskbar buttons”​
In Windows 11, taskbar behavior and button grouping is handled behind the scenes and can differ from Windows 10. If you’re coming from Windows 10:
  • You may expect classic options like “Never combine.” Windows 11’s taskbar design differs and may not match older layouts exactly.
Troubleshooting: “I don’t see Taskbar corner overflow / Other system tray icons”​
Try these:
  • Update Windows: Settings → Windows Update → Check for updates.
  • Restart Explorer:
  • Press Ctrl + Shift + Esc → find Windows Explorer → Restart.
  • Sign out and back in (or reboot) after major updates.
Troubleshooting: “My tray icons keep coming back”​
  • Some apps force their tray icon to be visible when running.
  • Check the app’s own settings for options like:
  • “Show tray icon”
  • “Minimize to tray”
  • “Run in background”
Troubleshooting: “Overflow doesn’t appear even with many apps open”​
  • On very large/high-resolution displays, you may need more open apps/windows to trigger overflow.
  • If you use multiple monitors, the overflow behavior can vary by taskbar configuration.
By combining Taskbar overflow (for open apps) with system tray settings (for background icons), you can keep Windows 11’s taskbar cleaner, easier to scan, and less distracting. You’ll spend less time hunting for windows or icons—and more time actually using your PC.
Key Takeaways:
  • Taskbar overflow keeps your taskbar readable when many apps are open.
  • You can choose which system tray icons stay visible vs. hidden.
  • Disabling unnecessary startup apps reduces tray clutter at the source.
  • These tweaks are beginner-friendly, reversible, and take only a few minutes.
This tutorial was generated to help WindowsForum.com users get the most out of their Windows experience.
