One useful test is to keep the headphones as your output while choosing a different microphone, such as your laptop’s built-in mic or a USB microphone. It won’t fix every setup, but it can help identify whether the headset’s call mode is responsible.
Why Bluetooth audio gets muffled
With Bluetooth Classic Audio, Windows uses the Advanced Audio Distribution Profile (A2DP) for stereo playback and the Hands-Free Profile (HFP) for two-way audio. Microsoft says HFP uses mono playback and microphone capture, with audio formats intended for voice rather than full-quality music.
Here’s the important Windows 11 wrinkle: using a separate microphone does not guarantee stereo playback during a call. Microsoft says Windows can also select HFP when an app opens a playback stream categorized as communications—even if that app isn’t using the headset microphone.
The steps below are therefore a practical test, not a promise that every calling app will keep the headset in stereo mode.
Choose your headphones and a separate microphone
You’ll need: Bluetooth headphones paired with your Windows 11 PC and another working microphone. A built-in laptop mic, webcam mic or USB microphone can work.
- Open Start > Settings > System > Sound.
- Under Output, select your Bluetooth headphones.
- Under Input, select the separate microphone—not the microphone named after your Bluetooth headset.
- Select the arrow next to the microphone to open its properties. Use the microphone test to record a short sample, then play it back if that option is available.
- Speak normally and adjust the input volume if your recording is too quiet.
Device names vary. Windows 11 may show a single output for a Bluetooth headset rather than separate “Stereo” and “Hands-Free” choices, so don’t worry if those labels aren’t present.
What success looks like: You can hear playback through the headphones, and the microphone test picks up your voice from the separate mic.
Check the calling app, too
A calling app can use its own device selections rather than the ones you expect from Windows. Open its audio or device settings and choose:
- Speaker/output: your Bluetooth headphones.
- Microphone/input: your separate microphone.
For the desktop version of Microsoft Teams, Microsoft documents these controls under Settings and more > Settings > Devices, in Audio settings. Select the speaker and microphone from their respective menus, then use Make a test call if it’s available in your version.
Play a familiar audio sample before and during the test call. If the sound remains clearer and your voice is audible on the recording, the separate-microphone setup is helping. If it becomes muffled only during the call, the app may still be triggering a communications mode. Close other apps that might be using the headset mic and test again.
A laptop microphone can also pick up keyboard noise or nearby voices. Check the recording before relying on it in an important meeting.
Check for Bluetooth LE Audio stereo
Some newer combinations can offer stereo playback while the headset microphone is active. According to Microsoft, this requires a compatible Bluetooth LE Audio device and PC, Windows 11 version 24H2 or newer, build 26100.4484 or newer, and the necessary manufacturer drivers. Support depends on the hardware, not just the Windows version.
To check the available setting:
- Connect your Bluetooth LE Audio headphones.
- Go to Settings > System > Sound.
- Under Output, select the arrow next to the headphones.
- Expand Format under the output settings.
- If Format when microphone is active appears, check whether Stereo (2 channels) is available.
Microsoft says that if this control is absent, the system does not currently support stereo playback while the microphone is active. Check for Windows and manufacturer driver updates; the option cannot be assumed to appear on every PC. If stereo causes glitches or lost audio, Microsoft suggests trying Mono (1 channel) for compatibility.
If the sound is still wrong
- Only one app has a problem? Go to Settings > System > Sound > Volume mixer. Under Apps, check that the app isn’t muted and is using the intended output device.
- The separate microphone isn’t working? Check its mute control and connection. Then open Settings > Privacy & security > Microphone and confirm microphone access and the appropriate app permissions are enabled.
- The headphones won’t connect or produce sound? Charge them, reconnect them, or remove and pair them again under Settings > Bluetooth & devices. Microsoft also recommends the Bluetooth troubleshooter in the Get Help app.
- Audio is poor even outside calls? Try the headphones with another device and check for Windows, Bluetooth driver and headset firmware updates. That helps distinguish a call-mode limitation from a broader connection or hardware problem.
The takeaway: start by separating the playback device from the microphone, then test the actual call. If Windows or the app still switches the headphones into hands-free mode, a wired headset or a compatible LE Audio setup may be a more dependable way to get clear playback and two-way audio at once.
