Check whether calibration matches your problem
Calibration is appropriate when the screen detects your finger but places the touch somewhere else—for example, consistently above a button or away from the edges.
Choose the next step according to what actually happens:
- Taps land nearby but miss their targets: Check the display settings, then calibrate.
- Taps affect another monitor: Run the touchscreen identification procedure under Setup first.
- Accuracy became worse immediately after calibration: Reset the calibration before trying again.
- The screen does not respond at all: Check its connection and whether Windows has enabled the touch device. A calibration target is not useful if the screen cannot detect taps.
- The screen registers touches without anyone touching it: Treat this as a ghost-touch problem rather than repeatedly recalibrating. Dell identifies obstructions, moisture, and physical or environmental interference as possible causes.
The distinction matters: Setup identifies which display receives touch; Calibrate adjusts where touch lands within that display. Changing one is not a substitute for the other.
Prepare the touchscreen and display configuration
Before starting:
- Have a working mouse or touchpad and keyboard available. Use them to navigate if touch becomes less accurate.
- Save your work before restarting.
- Confirm that the exact laptop or monitor model supports touch. A product family may include both touch and non-touch configurations.
- Clean the screen according to its manufacturer’s instructions and let it dry before testing.
- For an external touchscreen, check the touch-data connection as well as the video connection. On monitors that use a separate USB upstream cable, a working picture does not establish that touch is connected. Dell specifically lists a missing USB connection as a cause of non-working monitor touch.
Windows 10 users can still follow the Windows 10 procedure below, but Microsoft’s standard Windows 10 support ended on October 14, 2025. The availability of a calibration control should not be mistaken for continued standard operating-system support.
Check resolution and orientation before calibrating
Set up the display as you intend to use it before collecting calibration points. Microsoft recommends the display’s Recommended resolution; a lower resolution can produce a stretched, centered, or bordered image. Do not change resolution while calibration is running.
- Open Start > Settings > System > Display.
- If several monitors are connected, select Identify to see which number belongs to the touchscreen, then select that display in Settings.
- Check the settings for your Windows version:
- Windows 11: Under Scale & layout, check Display resolution and Display orientation.
- Windows 10: Under Scale and layout, check Display resolution and the orientation control.
- Use the resolution marked Recommended, unless the display manufacturer requires a different configuration. Make sure the selected orientation matches the screen’s physical position.
- If you changed the arrangement of several monitors, apply the arrangement and check that the mouse moves between them as expected.
For troubleshooting, make a note of any display setting before changing it. This gives you a clear way back if the change does not help, rather than leaving several untracked changes to diagnose.
Open Tablet PC Settings
The calibration procedure uses the traditional Control Panel dialog on both Windows versions.
- Open Start, type Control Panel, and open it.
- In the category view, select Hardware and Sound.
- Under Tablet PC Settings, select Calibrate the screen for pen or touch input.
- In the dialog that opens, use the Display tab.
You can also search Windows directly for Calibrate the screen for pen or touch input and open that result. Do not choose display color calibration: this task concerns touch position, not the screen’s colors. ASUS documents the touch-calibration entry and the same Control Panel route for Windows 10 and Windows 11.
Identify the correct touchscreen when using multiple monitors
Use this procedure if touching the external monitor controls the laptop screen, or if Windows associates touch with the wrong display. HP and ASUS document Setup > Touch input for identifying a touch display; GeChic also specifies this procedure for a touchscreen whose cursor appears on another monitor.
- In Tablet PC Settings, on the Display tab, select Setup.
- If Windows asks which input type to configure, select Touch input.
- Follow the identification instructions shown on the displays.
- When the identification message appears on a non-touch display, press Enter to move it to the next display.
- When it appears on the touchscreen, touch that screen with your finger. Follow any remaining on-screen instructions.
- Test a tap on the touchscreen. The action should now affect that display, not another monitor. The identification screen also provides Esc to close the tool if you need to abandon the process.
If this fixes the problem and taps are accurate, stop here. There is no need to add a custom calibration simply because the controls are available.
Calibrate taps that land in the wrong place
Before changing calibration: Keep your mouse or touchpad connected. Calibration changes touch positioning; inaccurate target taps can leave the result less usable. The recovery procedure is Reset, described in the next section.
- Open Tablet PC Settings and select the Display tab.
- Under Display options, choose the affected touchscreen if a display list is available. Check this carefully on a multi-monitor PC.
- Select Calibrate.
- If prompted to choose an input type, select Touch input, not Pen input.
- On the calibration screen, tap the crosshair each time it appears. Aim at its center with your finger.
- Complete the targets in the order presented. Keep the resolution unchanged throughout the procedure.
- When asked whether to save the calibration data, select Yes.
- Select OK to close Tablet PC Settings. Dell documents this sequence for Windows 10 and Windows 11.
Do not use the touch-calibration result to judge a separate active pen problem. Windows offers distinct pen and touch choices; this procedure deliberately selects finger touch.
Verify accuracy before making another change
Use a small, repeatable test rather than deciding from one successful tap:
- Open an application with clearly visible controls.
- Tap targets near the center, then near each side of the screen.
- Check the area that originally failed. A central button working correctly does not establish that the edges are accurate.
- On a multi-monitor system, confirm that each tap affects the touchscreen itself.
- Try scrolling and a long press as additional functional checks. Microsoft uses scrolling, pinch-to-zoom, and long-press tests when checking touchscreen operation on Surface.
These are practical checks, not a requirement to achieve pen-like precision with a fingertip. Look for reliable operation of normal controls and removal of the consistent offset you started with.
If accuracy is now satisfactory, stop. If the offset is worse or has moved elsewhere, reset instead of stacking further changes on top of the bad result.
Reset calibration if it makes touch worse
Reset in Tablet PC Settings is not Reset this PC. Here, the operation returns touch calibration to its default settings; it is not a Windows reinstall or a factory reset. ASUS documents restarting after this calibration reset.
- Use your mouse or touchpad to reopen Control Panel > Hardware and Sound > Calibrate the screen for pen or touch input.
- On the Display tab, select the affected display if a display list is present.
- Select Reset.
- Follow any input-selection prompt and select touch if a choice is offered.
- Select OK.
- Save open work and restart Windows.
- Repeat the center-and-edge accuracy checks after signing in.
If the default settings work better, leave them in place. If touch still controls the wrong monitor, return to Setup: resetting calibration and identifying the touchscreen address different parts of the configuration.
If Reset is unavailable, do not substitute Reset this PC. Recheck the selected display and proceed to connection and device checks rather than attempting registry changes.
Troubleshoot missing controls or persistent inaccuracy
Tablet PC Settings is missing or calibration cannot start
First establish that Windows can see the touch hardware.
- For an external monitor, check its manual for the required touch-data cable and reconnect that cable at both ends.
- Right-click Start and select Device Manager.
- Expand Human Interface Devices.
- Look for HID-compliant touch screen.
- If its right-click menu offers Enable device, select it and test touch again. Microsoft documents these controls for both Windows 10 and Windows 11. If the menu instead offers Disable device, do not select it just to enable touch—the device is already enabled.
If the touch device is missing, record that fact for the manufacturer. Do not assume calibration can repair a detection problem, and do not install an unrelated “touchscreen driver” from a third-party download site.
Touch still goes to another display
Return to Setup > Touch input and repeat identification carefully. Press Enter while the prompt is on a non-touch screen, and touch only the intended screen when prompted. Then test again before running calibration. GeChic’s monitor documentation specifically directs wrong-monitor touch problems to Tablet PC Settings configuration.
Touch works, but remains inaccurate after reset
Check for Windows updates:
- Windows 11: Start > Settings > Windows Update > Check for updates.
- Windows 10: Start > Settings > Update & Security > Windows Update > Check for updates.
Follow any restart request, then test again. For model-specific driver or firmware requirements, use the PC or monitor manufacturer’s support instructions. Microsoft notes that unexpected resolution changes can indicate a graphics-driver issue; ASUS also includes Windows packages and device drivers in touchscreen troubleshooting.
Avoid making driver removal the next automatic step. Microsoft specifically warns against uninstalling touchscreen drivers on Surface Pro X, because restoring them can require a full system reset. Follow the instructions for your exact model instead of applying a generic driver-removal procedure.
The same area stays unresponsive, or ghost touches continue
Stop recalibrating if the same region remains unusable after reset, or if touches occur without contact. Check for visible damage, dirt, moisture, or an obstructing screen accessory, following the manufacturer’s cleaning and troubleshooting guidance. A failed calibration alone does not prove hardware failure.
Escalate to the device manufacturer with the exact model, Windows version, connection arrangement, whether HID-compliant touch screen appears in Device Manager, and the results before and after Reset. Ask for the model’s touchscreen diagnostic procedure. On Surface, Microsoft uses a touch test outside Windows in UEFI to distinguish a Windows problem from likely hardware failure; use the documented procedure for your particular device rather than changing firmware settings experimentally.
