If your keyboard suddenly types everything in CAPITAL LETTERS, Windows may not be shouting at you. Caps Lock could be on, a Shift key might be sticking, or an accessibility setting may be keeping a modifier key active.
This guide applies to Windows 11 and Windows 10. You’ll need a mouse or other pointing device, a place to type such as Notepad, and, if possible, a second keyboard for comparison.
A person types at a desktop while an on-screen keyboard and alphabet pairs appear on the monitor. Start with Caps Lock and Shift​
  1. Open Notepad and type a few letters.
  2. Press Caps Lock once, then type again. If the letters return to lowercase, Caps Lock was likely enabled.
  3. If the problem remains, press and release the left Shift key, then the right Shift key. Check whether either feels jammed or fails to spring back.
  4. Type letters and number-row keys again.
A useful clue: on a typical English keyboard layout, Caps Lock changes letter case, while Shift also changes number-row keys into symbols. That distinction isn’t definitive—keyboard layouts and applications differ—but it can help you decide which key to investigate first.
If a key is physically stuck, don’t force it. Microsoft recommends checking for debris and using compressed air or gently vacuuming the keyboard surface with a dusting brush. Disconnect an external keyboard before cleaning it.
Bottom line: If Caps Lock changes the result, you may already be finished. If not, use Windows’ On-Screen Keyboard to investigate further.
Test with the On-Screen Keyboard​
The On-Screen Keyboard, or OSK, lets you type with a mouse without needing a touchscreen.
Open it using either method:
  • Press Windows key + Ctrl + O.
  • In Windows 11, go to Start > Settings > Accessibility > Keyboard and turn on On-screen keyboard.
  • In Windows 10, go to Start > Settings > Ease of Access > Keyboard and turn on Use the On-Screen Keyboard.
With Notepad open:
  1. Use the mouse to select the OSK’s Caps key once, then click a letter on the OSK.
  2. If necessary, click Caps again and test another letter. You’re looking for the state that produces lowercase letters.
  3. Check whether either Shift key appears active on the OSK. If you selected an on-screen Shift key, select it again to release it, then test another letter.
  4. Compare the result with typing on the physical keyboard.
If the OSK opens without the full set of letter keys, select General to return to its full layout. Microsoft notes that the keyboard can retain its last-used layout when reopened.
Interpret the result cautiously: Lowercase from the OSK but uppercase from the physical keyboard points toward the physical keyboard or its configuration. It does not prove a hardware fault. Likewise, uppercase from the OSK doesn’t rule out a physically held Shift key: a connected keyboard can still affect Windows while you use the OSK.
Check Sticky Keys​
Sticky Keys is an accessibility feature that lets you use keyboard shortcuts by pressing modifier keys one at a time. If Shift has been latched or locked, it can affect subsequent typing.
To test whether it is involved:
  1. Open Settings.
  2. Select Accessibility > Keyboard in Windows 11, or Ease of Access > Keyboard in Windows 10.
  3. Turn Sticky Keys off temporarily.
  4. Return to Notepad and test both physical and on-screen typing again.
If you rely on Sticky Keys, you can turn it back on after testing. Microsoft also documents pressing Shift five times as a shortcut for toggling the feature; the Settings page is a clearer way to see its current state.
While you are on the Keyboard settings page, you can enable Toggle Keys if you want an audible cue when Caps Lock is pressed. That makes an accidental toggle easier to notice, though it won’t repair a stuck key.
Is it the keyboard, Windows, or one app?​
The quickest way to narrow the cause is to change one thing at a time:
  • Try another app. If Notepad types normally but another program displays capitals, investigate that app’s formatting or input settings before changing Windows.
  • Disconnect an external keyboard. Then use the OSK to turn Caps off if needed and type in Notepad. If the problem disappears, reconnect the keyboard and test again.
  • Try a second keyboard on the same PC. If it works normally while the original does not, the original keyboard is a stronger suspect.
  • Try the original keyboard on another PC, if available. The same problem on both computers points toward the keyboard; normal behavior there makes a Windows setting, software conflict, or connection issue on the first PC more plausible.
  • Restart Windows and repeat the test if the cause is still unclear. If an external USB keyboard is involved, Microsoft also recommends trying another USB port and connecting directly rather than through a hub.
For a laptop, an external keyboard is useful for comparison, but the built-in keyboard remains connected and could still affect the test. If a laptop key appears physically stuck or the problem persists across tests, contact the device manufacturer or a qualified repair service rather than forcing the key.
A note for Windows 10 users​
Microsoft’s general support for Windows 10 ended on October 14, 2025. The keyboard steps above still apply, but consider moving to a supported Windows version. Eligible devices enrolled in Extended Security Updates can receive certain security updates for a limited period; that program does not restore full support.
For most cases, the path is straightforward: check Caps Lock and both Shift keys, test with the OSK, inspect Sticky Keys, then compare keyboards and apps. That sequence separates the usual suspects without jumping straight to driver removal or a Windows reset.
