This guide applies to the current Chromium-based Microsoft Edge on Windows 10 and Windows 11. Allow about 10 minutes for the basic checks. Menu names can vary between Edge versions, but you won’t need to delete your browser data or change the Windows registry.
First, identify the problem
Start with a regular Edge window, not an InPrivate or guest window. Microsoft says data entered in those temporary sessions is removed when the session closes.
Then consider what you’re seeing:
- No save prompt on any site: Check the password-saving setting and whether Edge is managed.
- No prompt on one site: Check the Never saved list.
- Password saved but not filled: Check autofill and any Windows authentication prompt.
- Password present on one device but absent on another: Check the Edge profile and password sync.
These are different jobs: saving a password, filling it, and syncing it across devices each have their own controls.
1. Check the Edge profile
Select the profile icon near the top of the Edge window. Choose the profile you normally use for the affected website. If you have personal and work profiles, make sure you’re not troubleshooting the wrong one.
Microsoft notes that switching profiles opens the selected profile in a separate window. Keep using that window for the remaining steps.
You don’t have to enable sync just to test whether Edge can save a password on this PC. Sync is for making supported data available across signed-in devices.
2. Turn on the password-saving prompt
- In Edge, select Settings and more—the three dots in the upper-right corner—then Settings.
- Select Passwords and autofill > Microsoft Password Manager.
- Select More settings.
- Turn on Ask to save passwords and passkeys.
On some versions, the path or label may instead be Profiles > Passwords and Offer to save passwords. Microsoft documents both layouts.
Return to a website where you know the sign-in credentials, sign in, and accept Edge’s save prompt if it appears. Then return to Microsoft Password Manager and look for the site under saved passwords.
If the entry is already saved but isn’t filling, check that Autofill passwords and passkeys is enabled under More settings. Edge may also ask for Windows Hello or your device sign-in credentials before revealing or filling a password; that prompt is a security check, not necessarily a saving failure.
3. Remove the site from “Never saved”
If you previously selected Never for a website, Edge can stop asking to save its password.
- Open Settings > Passwords and autofill > Microsoft Password Manager. On some versions, use Settings > Profiles > Passwords.
- Find the Never saved passwords or Never saved section.
- Find the affected site and select the X or remove control beside its entry.
- Return to the site, sign in again, and choose to save the password if Edge offers.
Removing the exception does not recover a password Edge never saved; it allows Edge to offer to save a future sign-in. Check the actual sign-in domain if the website sends you to a separate login page. Microsoft identifies the Never saved section as the place to manage sites excluded from save prompts.
4. Check password sync on both devices
If the password appears in the first PC’s password manager but not on another device, check both Edge windows:
- Select the profile icon and confirm that each device is using the intended account.
- Open Settings > Profiles > Sync.
- Turn on sync if it is off, then make sure Passwords is enabled in the list of data types.
- Repeat on the other device and check its password manager again.
Microsoft distinguishes signing in to Edge from enabling sync: signing in alone does not necessarily turn sync on. A work account and a personal account are separate choices, so check the account itself—not just a familiar profile picture.
If the credentials are saved locally but still don’t appear on the other device, check for a sync error or account sign-in prompt. For a work or school profile, an administrator may need to investigate the organization’s sync configuration.
5. Look for an organization policy
A greyed-out control or a message that Edge is managed by your organization is a reason to check for policy restrictions. It doesn’t, by itself, identify which policy is responsible.
For a read-only inspection, enter edge://policy in Edge’s address bar. Microsoft documents this page as the place to view applied browser policies. Useful names to mention to your IT team include:
- PasswordManagerEnabled: When disabled, it prevents saving or adding new passwords, although previously saved passwords can still be used.
- PasswordManagerBlocklist: Can disable the password manager’s save-and-fill interface for specified domains.
- SyncDisabled: Can prevent cloud sync; password syncing may also be restricted by a policy that excludes particular data types.
On a managed device, ask IT before changing anything. The restriction may be intentional, and attempting to work around it could conflict with your organization’s security rules.
Still not working?
Try another trusted website in the same regular Edge profile. If only one site fails, its sign-in flow or a site-specific restriction may be involved. If every site fails, revisit the global setting, profile, and policies.
You can also check for Edge updates through Settings and more > Help and feedback > About Microsoft Edge, then restart the browser if prompted. If an approved password-manager extension is involved, ask IT or follow its guidance before disabling it.
Above all, avoid clearing saved passwords or deleting the Edge profile as a first response. Microsoft notes that deleting synced passwords can remove them across synced devices. The goal is to get your password manager working—not give it a memory wipe.
