Before you begin: Isolate the cause in two minutes
Before changing drivers or reinstalling software, run two quick checks to determine whether the missing text comes from the document itself, the application printing it, or your physical printer driver. You only need clean paper and a few minutes.
- Open the problem document and print one affected page using Microsoft Print to PDF:
- In your app (such as Word, Edge, or Adobe Acrobat Reader), select File > Print (or press Ctrl + P).
- Set the printer to Microsoft Print to PDF, select a single page that has missing text, and select Print.
- Save the new PDF to your Desktop and open it.
- Print a Windows Test Page to your physical printer:
- Windows 11: Open Start > Settings > Bluetooth & devices > Printers & scanners, select your printer, select Printer properties, and on the General tab select Print Test Page.
- Windows 10: Open Start > Settings > Devices > Printers & scanners, select your printer, select Manage > Printer properties, and on the General tab select Print Test Page.
Interpret the results before moving to the next sections:
- The Microsoft Print to PDF file is also missing text: The problem lies in the source file, a missing or corrupted font on your PC, or the application's print engine. Focus on the font embedding steps below or try printing from a different application.
- The Microsoft Print to PDF file looks complete, and the Windows Test Page prints cleanly: Your printer hardware is working, and the fault is between your printer driver and the specific file or app. Use the PDF "Print as image," font substitution, and driver steps below.
- The Windows Test Page itself has faint, streaked, or missing text: The issue is likely physical (clogged nozzles, low toner, or a failing drum) rather than a Windows font or driver bug. Run your printer's built-in nozzle check or cleaning utility.
Check and fix font embedding in PDFs and Office documents
If a PDF or Office document uses a custom or non-standard typeface that is neither embedded in the file nor installed on your computer, Windows or the printer may substitute a fallback font—or drop the text entirely if the encoding cannot be mapped.
Verify font embedding in Adobe Acrobat Reader
- Open the PDF in Adobe Acrobat Reader (or Adobe Acrobat).
- Press Ctrl + D (or open Menu > Document properties on newer versions, or File > Properties on classic toolbars).
- Select the Fonts tab.
- Review every font listed under Fonts Used in this Document.
- Confirm whether each font shows (Embedded) or (Embedded Subset) next to its name.
If a font does not say Embedded or Embedded Subset, the PDF relies on your PC or printer having an exact local copy. If you created the PDF yourself, re-export it from the original application with font embedding enabled.
Embed fonts in Microsoft Word or PowerPoint before exporting
Microsoft 365 desktop apps for Windows allow you to embed TrueType and OpenType fonts directly into documents and presentations so they render consistently offline and during PDF conversion. Note that font vendors can set licensing flags inside a font file that block embedding; if a font is restricted, Word or PowerPoint cannot embed it.
- Open the original document in Word or PowerPoint.
- Select File > Options.
- In the left pane, select Save.
- Under Preserve fidelity when sharing this document (Word) or Preserve fidelity when sharing this presentation (PowerPoint), check Embed fonts in the file.
- Choose one of the two sub-options based on how you will use the file:
- Check Embed only the characters used in the document (or presentation) to keep file sizes smaller when others only need to view or print it.
- In Word, check Do not embed common system fonts to avoid bloating the file with standard fonts like Arial or Calibri. In PowerPoint, choose Embed all characters if others will edit the file later.
- Select OK, then save the document.
- If you are saving a Word document as a PDF, select File > Save As, choose *PDF (.pdf), select Options, check ISO 19005-1 compliant (PDF/A), select OK**, and save. PDF/A mode forces fonts to embed whenever licensing permits.
Print a PDF as an image to bypass font processing
When a PDF contains damaged font tables, complex overlapping layers, or unusual vector encodings that your printer's firmware cannot interpret, sending the page as a pre-rendered image avoids font processing on the printer altogether.
- Save the PDF to your local drive if you are viewing it inside Microsoft Edge, Chrome, or another web browser, then open the saved file in Adobe Acrobat Reader.
- Select Menu > Print (or File > Print, or press Ctrl + P).
- In the Print dialog box, select the Advanced button near the top.
- In the Advanced Print Setup window, check the Print As Image box.
- Select OK to close Advanced Print Setup, then select Print.
Expected result: Your computer rasterizes each page into a bitmap before sending it to the spooler, so every character visible on your screen should print. Because this sends a large image instead of compact text instructions, print jobs take slightly longer and fine text edges may appear marginally softer at standard resolution. Leave Print As Image unchecked for normal day-to-day printing once the problem document is finished.
Disable printer driver font substitution
Many PostScript and PCL printer drivers default to Substitute with Device Font, a legacy setting designed to save memory by swapping TrueType fonts on your PC for similar fonts stored inside the printer's hardware. If the printer's internal font lacks certain characters, symbols, or accents, those characters can disappear on paper.
Not all basic or built-in class drivers expose this setting. If your driver includes it, switch it to download fonts as softfonts:
- Open Printers & scanners:
- Windows 11: Select Start > Settings > Bluetooth & devices > Printers & scanners, select your printer, and select Printing preferences.
- Windows 10: Select Start > Settings > Devices > Printers & scanners, select your printer, and select Manage > Printing preferences.
- Look for an Advanced tab or an Advanced button (often found under Layout or Paper/Quality, depending on the manufacturer).
- Expand Document Options or Graphic if present, and locate TrueType Font.
- Change TrueType Font from Substitute with Device Font to Download as Softfont.
- If your PCL driver also displays a TrueType Font Download Option, try changing it from Automatic or TrueType to Bitmap (or Outline) if text still drops out.
- Select OK to save your preferences, then print a single test page from your document.
If changes made through Windows Settings do not stick for a specific program, open Printing preferences directly from inside that application's File > Print > Printer Properties dialog, as many applications override system defaults per print job.
Check, update, or switch your printer driver in Windows 10 and 11
An outdated, corrupted, or mismatched printer driver can drop text even when Print Preview looks perfect. This commonly happens after a major Windows feature update or when a manufacturer driver conflicts with newer Windows printing pipelines.
Check the current driver and test a built-in Microsoft class driver
Before downloading anything, check which driver your printer is using. Switching temporarily to a Microsoft class driver is a fast way to confirm whether a vendor driver is at fault.
- Open Printer properties:
- Windows 11: Start > Settings > Bluetooth & devices > Printers & scanners > select your printer > Printer properties.
- Windows 10: Start > Settings > Devices > Printers & scanners > select your printer > Manage > Printer properties.
- Select Change Properties at the bottom of the General tab if the settings appear grayed out (requires administrator rights).
- Open the Advanced tab and note the exact name shown in the Driver dropdown menu so you can switch back if needed.
- Open the Driver dropdown. If Microsoft IPP Class Driver or Microsoft PS Class Driver is listed, select it, select Apply, and test printing your document.
If the class driver prints all missing text, your manufacturer driver is the culprit and should be updated or reinstalled. If the class driver lacks features like duplexing or tray selection, update the vendor driver next.
Update the driver via Windows Update or the manufacturer
Microsoft recommends checking Windows Update first for compatible drivers, then checking the printer manufacturer's support site if Windows Update offers nothing newer.
- Windows 11: Open Start > Settings > Windows Update > Advanced options > Optional updates. Expand Driver updates, select any update listed for your printer, select Download and install, and restart your PC.
- Windows 10: Open Start > Settings > Update & Security > Windows Update. Select View optional updates if shown, expand Driver updates, select your printer's update, select Download and install, and restart your PC. Note that Windows 10 reached end of support in October 2025, so new driver packages may only be available directly from your printer manufacturer.
If Windows Update lists no printer drivers:
- Check your Windows architecture under Start > Settings > System > About (look at System type—most PCs are 64-bit operating system, x64-based processor, while Copilot+ and Surface ARM devices show ARM-based processor).
- Visit your printer manufacturer's official support website, search for your exact model, and download the latest driver package matching your Windows version and system type.
- Important for Windows on ARM PCs: Microsoft notes that some ARM PCs cannot install printers using legacy manufacturer installer executables. On an ARM device, skip the standalone installer unless the vendor explicitly supports ARM64, and instead add the printer through Settings > Bluetooth & devices > Printers & scanners > Add device.
Remove and reinstall the printer
Warning: Removing a network or shared printer clears its port configuration and custom printing defaults. Before removing a network printer, open Printer properties > Ports tab and write down its IP address or WSD/TCP port name in case Windows does not rediscover it automatically.
- Windows 11: Start > Settings > Bluetooth & devices > Printers & scanners, select your printer, and select Remove.
- Windows 10: Start > Settings > Devices > Printers & scanners, select your printer, and select Remove device.
- Restart your PC so Windows clears the active driver hooks.
- Return to Printers & scanners and select Add device (Windows 11) or Add a printer or scanner (Windows 10).
- Select your printer when it appears and let Windows install the recommended driver, or run the manufacturer's installer if you downloaded one.
Verify the fix
Print one or two pages of the original document that previously had missing text. Confirm that all headings, body paragraphs, mathematical symbols, and special characters appear at the right size and spacing, and that the page matches what you see on screen and in your Microsoft Print to PDF test file.
Troubleshooting and rollback
- Print As Image is grayed out or missing: You are likely printing from a web browser's built-in PDF viewer (such as Edge or Chrome) rather than Adobe Acrobat Reader, or the file is being handled by a restricted viewer. Download the PDF locally and open it in Adobe Acrobat Reader. If the Advanced button is still disabled inside Acrobat, check Help > Check for Updates and restart your PC after updating.
- Only one specific font disappears across all printers: That font file on your Windows PC may be corrupted or lack printable outlines. In Word, press Ctrl + A to select the text and temporarily switch it to a standard system font such as Arial or Calibri. If the text prints normally, reinstall the problematic font or replace it in the document template.
- Missing text or print errors started immediately after a driver update: Roll back the driver in Device Manager. Select Start, type Device Manager, and open it. Expand Printers or Print queues, right-click your printer, and select Properties. On the Driver tab, select Roll Back Driver (if available), follow the prompts, and restart your PC.
- Print jobs stall in the queue or disappear after changing drivers: Clear and restart the Print Spooler service.
- Warning: Clearing the spooler folder deletes all pending print jobs for every printer on the PC.
- Press Windows key + R, type
services.msc, and press Enter. - Right-click Print Spooler and select Stop (or run
net stop spoolerin an elevated Command Prompt). - Press Windows key + R, type
%WINDIR%\System32\spool\PRINTERS, and press Enter. Delete all files inside this folder without deleting the folder itself. - Return to Services, right-click Print Spooler, and select Start (or run
net start spooler). Confirm Startup type is set to Automatic.
- Windows 11 blocks your manufacturer driver: Check whether Windows protected print mode is enabled under Start > Settings > Bluetooth & devices > Printers & scanners > Printer preferences. Protected print mode enforces Mopria-certified inbox drivers and blocks third-party printer drivers. If your printer requires a vendor driver to render fonts properly, turn off Windows protected print mode there (you can re-enable it later from the same screen, though turning it on removes third-party drivers and XPS/Fax printers).
- Text is still missing on every PC and every application: Print a status or configuration page directly from the printer's physical control panel. If the printer's own internal report drops text, or if the same PDF drops identical characters when printed from a second computer, contact the printer manufacturer's support for a firmware update or hardware service.
