Set Up Mono Audio and Visual Sound Alerts in Windows 10/11​
Difficulty: Beginner | Time Required: 10 minutes
Windows includes several accessibility features that can make audio easier to notice and understand. Two of the most useful are Mono audio and visual sound alerts.
Mono audio combines the left and right stereo channels into one shared audio channel. This is helpful if you hear better in one ear, use a single earbud, have one speaker that does not work, or simply do not want to miss sounds that are normally played only on the left or right side.
Visual sound alerts make Windows flash part or all of the screen when a system sound plays. This can help if you are hard of hearing, working in a noisy environment, using your PC with the sound muted, or relying on visual cues instead of audio notifications.
This guide covers both Windows 10 and Windows 11.
Prerequisites​
Before you begin, make sure:
Quick walkthrough
  • You are signed in to Windows.
  • Your audio device is connected and working, if you want to test mono audio.
  • You have permission to change Windows Settings.
  • You are using Windows 10 or Windows 11.
Version note:
These options are available in modern versions of Windows 10 and Windows 11. The exact wording may differ slightly depending on your Windows version, update level, or device manufacturer.
Part 1: Turn On Mono Audio in Windows 11​
Windows 11 Accessibility Audio settings with the Mono audio toggle.
Use these steps if you are running Windows 11.
  • Click the Start button.
  • Select Settings.
    You can also press Windows + I to open Settings quickly.
  • In the left sidebar, select Accessibility.
  • Under the Hearing section, select Audio.
  • Find the option labeled Mono audio.
  • Turn the Mono audio switch On.
Once enabled, Windows will combine stereo sound into a single mono output. This means sounds that would normally play only through the left or right speaker will now be heard through both sides.
Test Mono Audio in Windows 11​
To confirm the setting is working:
  • Play a video, song, or audio test that uses left and right stereo channels.
  • Listen through headphones or speakers.
  • You should hear both left and right channel sounds together instead of separated.
Tip:
Mono audio is especially useful when wearing only one earbud. It helps prevent missing sounds from the other audio channel.
Part 2: Turn On Mono Audio in Windows 10​
Use these steps if you are running Windows 10.
  • Select Settings.
  • Choose Ease of Access.
  • In the left menu, select Audio.
  • Under Turn on mono audio, switch the setting to On.
Windows 10 will now play combined left and right audio through a single mono mix.
Note:
In Windows 10, accessibility settings are found under Ease of Access. In Windows 11, Microsoft renamed this section to Accessibility.
Part 3: Set Up Visual Sound Alerts in Windows 11​
Windows 11 Accessibility Audio settings showing visual sound alert options.
Visual sound alerts make Windows flash your screen when certain system sounds or notifications occur.
  • Open Settings using Windows + I.
  • Select Accessibility from the left sidebar.
  • Under Hearing, select Audio.
  • Look for Flash my screen during audio notifications.
  • Open the drop-down menu.
  • Choose one of the available options:
  • Never
    No visual alert is shown.
  • Flash the title bar of the active window
    Only the title bar of the current window flashes.
  • Flash the active window
    The currently active window flashes.
  • Flash the entire screen
    The whole screen flashes when an audio notification occurs.
For most users, Flash the active window is a good starting point. It is noticeable without being as intense as flashing the entire display.
Warning:
If flashing visuals bother your eyes, trigger headaches, or may affect a medical condition such as photosensitive epilepsy, avoid using Flash the entire screen. Try a less intense option or leave the feature off.
Part 4: Set Up Visual Sound Alerts in Windows 10​
In Windows 10, the same feature is available under Ease of Access.
  • Click Start.
  • Open Settings.
  • Select Ease of Access.
  • In the left menu, choose Audio.
  • Find Show audio alerts visually.
  • Choose one of the options:
  • No visual alert
  • Flash active caption bar
  • Flash active window
  • Flash entire display
If you are unsure which to choose, start with Flash active window. If you still miss alerts, try Flash entire display.
Part 5: Optional Quick Access Method​
You can also search directly for the settings.
Windows 11​
  • Press Windows on your keyboard.
  • Type Mono audio or Audio accessibility settings.
  • Select the matching Settings result.
  • Turn on Mono audio or adjust visual notification options.
Windows 10​
  • Press Windows.
  • Type Ease of Access audio settings.
  • Open the result.
  • Enable Mono audio or choose a visual alert option.
This method is useful if you do not want to navigate through several Settings pages.
Tips and Troubleshooting​
Mono Audio Is On, But Sound Still Seems Uneven​
If sound still seems louder on one side:
  • Open Settings.
  • Go to System > Sound.
  • Select your output device, such as speakers or headphones.
  • Check the left/right balance settings if available.
  • Make sure both sides are set to similar volume levels.
Some audio drivers or manufacturer apps, such as Realtek, Dolby, Waves MaxxAudio, or vendor-specific sound utilities, may also include balance or enhancement settings.
Visual Alerts Are Not Showing​
If you enabled visual sound alerts but do not see anything:
  • Make sure the setting is not set to Never or No visual alert.
  • Try selecting Flash entire screen temporarily for testing.
  • Check whether the app you are using actually plays a Windows system sound.
  • Test with a Windows notification or system sound.
  • Restart the computer if the setting does not appear to apply.
Note:
Visual sound alerts are mainly designed for Windows system sounds and notifications. Some third-party apps, games, or web apps may use their own sound systems and may not trigger the Windows visual alert feature.
Check Notification Settings​
Windows 11 Notifications settings page with notification toggles.
If you expected a notification but nothing happened:
  • Open Settings.
  • Go to System > Notifications.
  • Make sure notifications are enabled.
  • Check the specific app’s notification settings.
  • Confirm that the app is allowed to play sounds.
If app notifications are disabled, Windows may not show or sound the alert.
Use Both Features Together​
Mono audio and visual alerts can be used at the same time. This is often the best setup for users who want to make sure they do not miss important alerts.
For example:
  • Turn on Mono audio so all sound is heard in one ear or through one speaker.
  • Set visual alerts to Flash active window.
  • Keep regular notifications enabled for important apps like Mail, Teams, Calendar, or security software.
Consider Focus Assist or Do Not Disturb​
If you still are not receiving notifications, check whether Windows is suppressing them.
On Windows 11:
  • Open Settings.
  • Check Do not disturb settings.
On Windows 10:
  • Open Settings.
  • Go to System > Focus assist.
  • Make sure Focus assist is not blocking notifications you want to receive.
Mono audio and visual sound alerts are simple but powerful accessibility tools built into Windows 10 and Windows 11. Mono audio helps ensure you do not miss sounds that are split between left and right stereo channels, while visual alerts provide an on-screen cue when Windows plays notification sounds.
These settings are quick to enable, easy to adjust, and useful for many situations—not only for accessibility needs, but also for noisy rooms, shared workspaces, muted PCs, single-earbud listening, or troubleshooting speaker issues.
Key Takeaways:
  • Mono audio combines left and right stereo channels so you can hear all sounds through one earbud, speaker, or side.
  • Visual sound alerts flash part or all of the screen when Windows plays audio notifications.
  • Windows 11 uses Settings > Accessibility > Audio.
  • Windows 10 uses Settings > Ease of Access > Audio.
  • Start with a moderate visual alert option, such as flashing the active window, before using full-screen flashing.
  • These features can be used together for a more noticeable and accessible notification experience.
This tutorial was generated to help WindowsForum.com users get the most out of their Windows experience.
