The thread discusses issues installing GTA EFLC on Windows 8 64-bit, with the original poster encountering errors related to 16-bit application support. Contributors suggest that 16-bit games generally cannot run on Windows 8 64-bit and recommend solutions such as using a 32-bit virtual machine or Windows XP Mode, which the original poster has already attempted unsuccessfully. Overall, the consensus indicates compatibility limitations with 16-bit applications on modern 64-bit Windows systems, with suggestions leaning toward virtualization as a potential workaround.
Fotis Makris
Hello everyone and Happy New Year,
I am here cause I want to ask you for any solutions for my problem.
I am trying to install GTA EFLC in Windows 8 (Officially Activated) but I get the following message:
Starting Installation via Autorun.exe: Unsupported 16-bit Application. The Program or feature "\??\E:\Setup.exe cannot start or run due to incompatibility with 64-bit versions of Windows.
Please contact the software vendor to ask if a 64-bit Windows compatible version is available.
Starting Installation directly from Setup.exe: This app can't run on your PC. To find a version for your pc, check with the software publisher
GTA IV run perfectly also other games. I don't know what is this problem with this.
If there are any solutions please answer me here.
Thank you.
I suspect the 16 Bit game will not run on Win 8 64 Bit. I have heard some have had great results with Win 8 32 Bit with installing 16 Bit apps, but that Win 8 64 Bit will not run any 16 Bit apps.
Perhaps using a 32 Bit VM (using Win XP 32 Bit) might work.
you may need to update your games for windows.
Try installing the latest version found here: Link Removed
Fotis Makris
Thread Author #5
The latest, I tried to update with the link you sent me but still the same problem.
In my other computer where I have Windows 8 Pro 32-bit the installation works normally
Hmm.. did you have the game running under windows 7 64bit?
Medico
My thoughts too Ted, hence my question..
Fotis Makris
Thread Author #9
Yes, I did. Before Windows 8 Pro on my other computer I used Windows 7 Ultimate 64-bit, worked normally.
I was also thinking about that. I tried Windows XP Mode with Windows Virtual PC but I cannot install Virtual PC because of some
certificate problem.
Medico
XP mode will not work on Win 8. Try using Hyper-V that is built in to Win 8.
Fotis Makris
Thread Author #11
I have tried but I cannot find it inside "Turn On/Off Windows Features" menu.
Medico
Which version of Win 8 do you have? Hyper-V is only available on 64 Bit versions of Win 8 Pro and Enterprise.
