The thread discusses a user experiencing reduced gaming performance after upgrading to Windows 8 on an HP Pavilion dv6-6121se, with issues related to incorrect GPU recognition and driver problems for the AMD Radeon HD 6400M series. Attempts to install drivers, including compatibility adjustments and alternative driver links, have not resolved the issue, and the user reports the integrated Intel HD 3000 GPU persists during gaming. The community suggests checking BIOS settings and driver compatibility, but no definitive solution has been provided, and the user indicates limited BIOS options and ongoing frustrations.
STM123
I have a HP Pavilion dv6-6121se Link Removed i recently upgraded to windows 8 pro and my games got slower and in game options i could only select directx 9 until later i got battlefield 4 and it says gpu cant buffer frame and it said gpu was intel hd 3000 i checked system info and saw it recognized my hd 6400m series card as 7400m series this wasnt right because i had 6400m as hp said in its page and in win7 the catalyst software was there but it is not there now. so i downloaded win8 driver from this page Link Removed but nothing worked.
Can you enter the bios and see if there is a setting for making the add in card/GPU as default or turning off the graphics on the CPU.
Normally laptop drivers are provided by the manufacturer. I notice on your lappies support page only Windows 7 driver is available. I would still give that a try though but first right click it, choose properties and then compatibility. Change to win 7 and hopefully you should be ok.
Josephur
Windows Forum Admin
Try this driver:
Note its 64-bit driver.
STM123
Thread Author #5
Installed successfully, system recognizes it but when i play battlefield 4 it still doesn't work and says gpu intel hd 3000 and no improvement in gaming.
STM123
Thread Author #7
Ok I will check and I forgot to say in the catalyst software I can't do any settings it only says display no other tabs like power switchable graphics.
STM123
Thread Author #9
Yes but no solution and my bios hardly does anything it doesn't have most advanced options sorry for late reply
