maifs
hi
i am facing a problem in turbo c/c++ graphics.
i am unable to run my any .cpp graphics file.
its doing hang/held the application. i have to terminate it abnormally.
what should i have to do?
It seems like you are encountering issues with running .cpp graphics files in Turbo C/C++ and the application hangs or freezes, leading you to terminate it forcibly. Here are some steps you can take to troubleshoot and resolve this issue:
Steps to Resolve Turbo C/C++ Graphics Hang Issue:​
  • Check Code for Errors:
  • Make sure there are no errors in your C/C++ code that might be causing the program to hang. Debug any logic errors that could be leading to the freezing.
  • Restart Turbo C/C++:
  • Sometimes, software glitches can cause freezing issues. Try restarting Turbo C/C++ and see if the problem persists.
  • Update Graphics Drivers:
  • Ensure your graphics drivers are up to date. Outdated drivers can...
  • Ensure your graphics drivers are up to date. Outdated drivers can sometimes cause compatibility issues with certain applications.
  • Run in Compatibility Mode:
  • Try running Turbo C/C++ in compatibility mode. Right-click on the application shortcut, go to Properties, and under the Compatibility tab, select an earlier version of Windows that the application is known to work well with.
  • Disable Antivirus:
  • Temporarily disable your antivirus software and run Turbo C/C++ to see if the issue is related to any security software interference.
  • Reinstall Turbo C/C++:
  • If none of the above solutions work, consider uninstalling and then reinstalling Turbo C/C++ to ensure a fresh installation.
  • Use an Alternative IDE:
  • Consider using a modern C/C++ IDE like Visual Studio, Code::Blocks, or Dev-C++ for better compatibility and stability.
  • Seek Community Support:
  • If the issue persists, seek help from online forums or communities dedicated to Turbo C/C++ or graphics programming for further assistance. By following these steps, you should be able to diagnose and resolve the hanging issue you are experiencing with your .cpp graphics files in Turbo C/C++. If you need further assistance or encounter any specific errors, feel free to provide more details for a more targeted solution.
