The WindowsForum thread discusses a user's issue with connecting an older tube TV to their Windows 7 PC via S-Video and EUROSCART, where they cannot set the TV resolution above 748x480, unlike in Windows XP. Participants suggest checking driver settings, trying different connection cables, and adjusting NVIDIA profile configurations, but the original poster suspects the problem isn't driver-related. Overall, the thread shows a collaborative effort to troubleshoot resolution limitations, with the user planning to test the proposed solutions.
XealBizz
Well-Known Member
Hello, i have an older tube TV Set, that is connected to my computer thru S-Video (Computer), EUROSCART (the TV) and i recently installed Windows 7. In my old Win XP, it allowed me to set the resolution for the TV Set at 1024x768, and i could watch movies on my TV, but now, in Win 7, it won't allow me to set the TV resolution above 748x480, and this resolution is to low for any movie to be watchable.
I mention that my graphics card is Nvidia GeForce 9600 GT.
If anyone can help... thanks in advance.
Re: Thanks
you might want to check the profiles on the nvidia drivers, usually they allow you to add the various tv formats manually if the standard one doesnt pick up the correct rez
XealBizz
Well-Known Member
Thread Author #3
Thanks
Thanks... but i don't think it's a driver problem. I have the latest NVIDIA Drivers.
nasspi
Re: Thanks
Try S-video to 3RCA see if the problem persists check also your output signal it should be analog i believe on your second display
Highwayman
Re: Thanks
XealBizz
Well-Known Member
Thread Author #6
Thanks for your suggestions....
Thanks for all your suggestions, i will try them and keep you posted...b-)
