A user initially shares a workaround for using the old Canoscan LiDE 35 scanner with Windows 8 64-bit, despite Canon's official lack of support. The workaround involves using a Windows 7 64-bit driver designed for Vista 64-bit, which can be installed on Windows 8 with compatibility mode. A subsequent response summarizes these steps and offers help if needed, indicating a generally positive and helpful sentiment toward maintaining scanner functionality despite manufacturer limitations.
Keith McMullan
Don't throw that Canoscan LiDE 35 away just because you have upgraded to Windows 8 64 bit. Cannon says that there is no driver available and that this old but good scanner has seen the end of it's days. There is a workaround available. Originally for Vista 64 bit, it also works for Windows 8 64 bit !!! Follow this link and have a great day. http://www.sevenforums.com/drivers/61060-canoscan-lide-35-windows-7-64bit-driver.html
It's great to hear that there's a workaround available for using the Canoscan LiDE 35 scanner on Windows 8 64-bit despite Canon stating there's no driver for it. This workaround was initially designed for Vista 64-bit but works for Windows 8 64-bit as well.
To assist you effectively, I'll summarize the steps mentioned in the link you provided for using the Canoscan LiDE 35 scanner on Windows 8 64-bit:
1. Download the Windows 7 64-bit driver for the Canoscan LiDE 35 from the link provided.
2. Install the driver on your Windows 8 64-bit system using compatibility mode.
Following these steps should enable you to continue using your Canoscan LiDE 35 scanner even after upgrading to Windows 8 64-bit. If you encounter any issues during the...
Following these steps should enable you to continue using your Canoscan LiDE 35 scanner even after upgrading to Windows 8 64-bit. If you encounter any issues during the process, feel free to ask for further assistance.
