Those are fine - especially the idle temps. I recommend you use a real-time hardware monitoring program (if not already using one). I like and use CoreTemp for newer Intel and AMD64 CPUs. It sits in your Notification Tray and you can configure it to display all cores, or just the hottest (which is what I do).
When the temps start rising above 60°C on a regular basis, it is probably time to clean the interior of all the heat trapping dust sucked in by the case fans. Of course ambient (room) temperatures will play a major role in heat control too.
Pauli
Fantastic Member
I don't know Intel, but I believe they have the same as AMD i.e. temperature control, which means that the CPU will give Windows a command to shut the system down if the temperature goes high = all is in safe control. So, the fire brigade is there, at all times, no need to be worried - overheating is theoretical nowadays.
About the general heats, and keeping fans at low noise level, it's very much about having your fans placed optionally. You need to have incoming air optional, lowest = coolest possible level, and outgoing air at highest = hottest possible level. I've theorized about building a computer inside a small refrigerator = minibar, in order to get it working with ~ zero fans.
Anyway, if I have the right picture, Intel works at lower temps than AMD. I would agree with Digerati: anything above 60 degrees is nigh to critical.
Digerati
Microsoft MVP
The CPUs do not give the OS a command to shut down, they just shut down. On some motherboards, the CPUs communicate with the BIOS to control fan speeds, and in some cases (most notably, notebook motherboards) with the bus clocks to toggle down in speed to lower temps.
In any case, the idea is the same, self-preservation - to prevent the CPUs from burning up. And there are Windows based hardware monitoring programs that can be used to prevent heat related damage too but the real protection comes comes from within the CPU itself, and with its communication with the motherboard.
So in theory - a CPU should never burn it, it should shut itself down before that happens. But it assumes the CPUs protection feature is working properly. It also assume normal clocking.
Assuming Titanic meant "optimally", I agree. Generally, as noted before, you want good front to back flow through the case.
I have seen computers inside refrigerators, immersed in liquid nitrogen, and all sorts of other "novelty" setups. There are even tutorials out there. And generally they work, but generally they are not low-maintenance either.
There are "passive" (no fans) cooling systems for CPUs, graphics cards, PC cases used often with HTPCs (home theater PCs) where any fan noise at all is totally unacceptable. There are also whole websites dedicated to Quiet PCs and Silent PCs - if really interested.
Pauli
Fantastic Member
Thanks for correcting me. And yes, I meant "optimally".
