The thread discusses a user's challenge with maintaining consistent drive letter assignments for internal drives in Windows 10, especially after swapping drives, which disrupts their workflow. Assistance is offered through methods like using Disk Management and editing the registry, but the user expresses hesitation and confusion about the registry approach. Overall, the conversation reflects a frustrated but seeking approach, with suggestions leaning toward advanced solutions and caution advised due to potential risks.
cemster
I tried all kinds of formulas to phrase the search in Google but I couldn't get too close...
Hence I am here now... Link Removed
So I have about a dozen drives in my win 10 system. And sometimes I need to swap them to get clones or images or what not.
The problem I have is even when I put back the drives with the same cablings they still get different drive letters... So I keep changing, swapping the letters every time to get back to how they were before... It is a workstation so it is important that they are assigned to specific letters in order for me to keep my workflow...
So the question is is there any way I can assign drive letters permanently no matter what, of course unless I change them again.
I am really tired of reassigning 12 drives everytime I swap drives back and forth.
There must be a way to prevent that... I am hoping...
Seems your present method (Disk Management) is not working so well.
You could try it in the registry, if you are comfortable with that.
HKEY_LOCAL_MACHINE\SYSTEM\MountedDevices
Mike
Windows Forum Admin
Are you assigning the drive letter in Disk Management? This will usually help make it permanent, as opposed to using File Explorer.
cemster
Thread Author #3
Thank you for replaying,
Disk Management is the only place I know to change the drive letters...
cemster
Thread Author #4
Oh! I am sorry... None of these drives are external... All my drives are internal HDDs with one SSD exception...
davehc
cemster
Thread Author #6
first of, thank you for trying to help me out here,
I am comfortable but not necessarily capable. That means I have to research and study. At this point that scares me more than doing what I am doing now.
Maybe if you could direct me to a nice path with a nice view, I would be more willing to get my hands dirty... :)
davehc
If interfering with the registry, is not your thing, then perhaps it is better if you stay clear of it!
But, for what it is worth, this is the picture you will see, in the path I suggested. You can change these letters around, but, you have to be wary of any program which are currently dependant on the paths shown. In particular, the "C" path, which will normally contain the OS.
If you are going to take this daring tas, first you must back up your entire computer wilh a bootable image
37323
cemster
Thread Author #8
I have tinkered with it few or more times for one or the other reason, and I even had Registry Finder at one point because it was faster to find things or something... Still, I can not consider myself like I know something.
The only thing is that I don't quite get is why changing the letters here would do any difference?
I assume when I change a drive letter in Disk Management, at that moment that process writes these entries here, am I wrong?
I feel pretty hopeless at this point;
I am wondering if the system does not recognize any sort of identifying mark in the physical drive, or if the drive itself could have some sort of information that coded that would help system for correct assignment there is not much can be done for this ridiculous problem...
Thank you again, I appreciate your inputs...
