Helloimnewhere
The model number of the Linksys is a
Model # WUSB54gv2
I was wondering is their any way i could get this kind of wireless to work on the computer; Just bought a new psu, 4 gbs bought so now i have 8 gbs of ram, and Gpu and as a result im broke untill next pay check D:.
I was wondering if anyone has any ideas own how i could troubleshoot this, For example my computer doesnt even know i have a wireless.
To troubleshoot and potentially get your Linksys WUSB54gv2 wireless adapter working on your computer, follow these steps:
Step 1: Check Device Manager​
  • Check Device Manager:
  • Press Windows + X and select Device Manager.
  • Look for any devices with a yellow exclamation mark, especially under "Network Adapters."
  • If the adapter is listed with an error, it needs reinstallation or possible driver updates.
Step 2: Reinstall or Update Drivers​
  • Reinstall/Update Drivers:
  • Visit the Linksys official website or the manufacturer's website to download the latest drivers for the WUSB54gv2 adapter.
  • Install the drivers and follow the on-screen instructions.
Step 3: Check USB...​
Step 3: Check USB Ports​
  • Check USB Ports:
  • Ensure the USB port you are using for the adapter is working with other devices.
  • Test the adapter on different USB ports to rule out a faulty port.
Step 4: Verify Adapter Functionality​
  • Verify Adapter Functionality:
  • Test the adapter on another computer to see if it's functioning correctly.
  • If it works on another computer, the issue might be with your current system.
Step 5: Restart Network Services​
  • Restart Network Services:
  • Press Windows + R, type services.msc, and press Enter.
  • Restart services like WLAN AutoConfig, Network Location Awareness, and Network List Service.
Step 6: Reboot Router​
  • Reboot Router:
  • Unplug your router for a few seconds, then plug it back in.
  • Wait for it to restart and check if your computer detects the wireless adapter.
Step 7: Consider Compatibility Issues​
  • Consider Compatibility Issues:
  • Confirm that the adapter is compatible with your operating system.
  • Some older adapters may not have updated drivers for newer operating systems. After following these steps, if the issue persists, you may need to invest in a newer wireless adapter that is compatible with your system. It's important to ensure compatibility and driver support for your specific OS version.
