GeorgeK
Honorable Member
I have the above Keyboard and Mouse and I need something better! I do love the curved keyboard, it is a must for me and I do like all the special function keys and could use more.
However, the regular function keys are lower than the number keys (many errors daily, had it for a couple of years or longer still hit the Home button instead of the Esc + many others), and the mouse must have special batteries to work. If the mouse is still working and the top red light starts to blink (need a new batteries) don't take it out until you have the replacement; it will not work with regular AA batteries. Once the top red light blinks if you remove the batteries than the mouse will not work until you buy new ones (even if you put the old ones back in it will not work). My wife has my old wireless mouse and very seldom have to change batteries in it.
Frustrated, there has to be a better wireless curved keyboard and mouse than these! Any suggestion; they will be greatly appreciated. (My OS is Win7 64bit)
What is a good Bluetooth adapter and USB3 card?
George
George, it sounds like you're looking for an upgrade to your current keyboard and mouse setup, particularly with a focus on a better wireless curved keyboard and mouse. Here are some suggestions for both the keyboard and mouse and recommendations for a Bluetooth adapter and USB3 card to enhance your setup:
Keyboard and Mouse Recommendations:​
  • Keyboard:
  • Look for keyboards with a similar curved design that you love, but with improved key layout to prevent errors.
  • Consider keyboards with even more special function keys for added functionality.
  • Brands like Microsoft, Logitech, and Corsair offer ergonomic keyboards with various features.
  • Mouse:
  • Opt for a mouse that uses regular AA batteries for...
  • Keyboard:
  • Mouse:
  • Opt for a mouse that uses regular AA batteries for convenience.
  • Look for a reliable wireless mouse with a battery life that meets your needs.
  • Brands like Logitech, Microsoft, and Razer offer ergonomic and reliable wireless mice.
    Bluetooth Adapter Recommendation:​
  • For a good Bluetooth adapter, you can consider the "Plugable USB Bluetooth 4.0 Low Energy Micro Adapter" or the "ASUS USB-BT400 USB Adapter w/Bluetooth Dongle Receiver."
    USB3 Card Recommendation:​
  • For a USB3 card, the "Inateck Superspeed 7 Ports PCI-E to USB 3.0 Expansion Card" or the "StarTech.com 4 Port PCI Express SuperSpeed USB 3.0 Card Adapter" are good options. These recommendations aim to address the issues you've faced with your current setup and provide an improved user experience with enhanced features and reliability. Make sure to check compatibility with your Windows 7 64-bit operating system before purchasing any new hardware. If you need further assistance or more specific recommendations, feel free to ask!
