RobertG
I am connecting a Canon HV20 Video Camera to a Pinnacle 710-USB. (this device is recognized in the device manager as a Pinnacle Marvin Bus 64)...
The Camera is recognized as a 61883 Class Bus ????? but with an error (This device is not working properly because Windows cannot load the drivers required for this device. (Code 31)).
any idea how to solve this driver issue.
To resolve the driver issue with your Canon HV20 Video Camera connected to a Pinnacle 710-USB device, which is recognized in Device Manager as a Pinnacle Marvin Bus 64, you can try the following steps:
1. Update the Driver​
  • Update Automatically:
  • Right-click on the device in Device Manager.
  • Select "Update driver" and choose "Search automatically for updated driver software."
  • Update Manually:
  • Visit the Canon and Pinnacle websites to download the latest drivers for your camera and the Pinnacle device. Install these drivers manually.
    2. Uninstall and Reinstall the Driver​
  • Uninstall Driver:
  • In Device Manager, right-click on the device.
  • Choose "Uninstall device" and check the box to...
  • Update Manually:
  • Uninstall Driver:
  • Choose "Uninstall device" and check the box to delete the driver software for this device.
  • Reinstall Driver:
  • Unplug the devices, restart your computer, and then reconnect them.
  • Windows may reinstall the drivers automatically. If not, install the drivers manually.
    3. Check for Windows Updates​
  • Update Windows:
  • Make sure your Windows system is up to date with the latest updates.
  • Sometimes, driver issues are resolved through Windows updates.
    4. Roll Back the Driver​
  • Roll Back Driver:
  • If a recent driver update caused the issue, you can roll back to the previous driver version in Device Manager.
    5. Check Hardware Compatibility​
  • Compatibility Check:
  • Ensure that your Canon HV20 Video Camera and Pinnacle 710-USB device are compatible with your version of Windows.
    Additional Tips​
  • Safe Mode: You can try resolving driver issues in Safe Mode to exclude any third-party software conflicts.
  • System Restore: If you recently installed new software that might have caused the issue, consider using System Restore to revert to a point before the problem occurred. Try these steps to troubleshoot and resolve the driver issue with your Canon HV20 Video Camera and Pinnacle 710-USB device. If the problem persists, feel free to provide more details for further assistance.
