westentertainer
hi i installed windows 7 on my pc on a seperate sata drive now i can boot vista/xp/windows 7 ,great!
only problem is i have a ide controler because there was only one ide port so i had to buy a 4 way controler that my lightscribe dvd is conected to,,only problem is it does not see the dvd drive now ,i have tried to update the drivers,windows 7 finds them but states wrong plattform any help please.
It sounds like you are facing an issue with getting Windows 7 to recognize your IDE controller that is connected to your lightscribe DVD drive. Here are some steps you can take to troubleshoot and resolve this issue:
Steps to Resolve the Issue:​
  • Check IDE Controller Compatibility:
  • Ensure that the IDE controller you purchased is compatible with Windows 7. Check the manufacturer's website for any updated drivers specifically designed for Windows 7.
  • Update IDE Controller Drivers:
  • If Windows 7 is stating that the drivers are for the wrong platform, there might be compatibility issues. Try the following:
  • Download the latest drivers for the IDE controller from the manufacturer's website.
  • Right-click on...
  • Right-click on the IDE controller in Device Manager, choose "Update Driver Software," and select "Browse my computer for driver software."
  • Compatibility Mode:
  • If the drivers are not installing properly due to compatibility issues, you can try installing them in Compatibility Mode.
  • Right-click on the driver installer file.
  • Select "Properties" and go to the "Compatibility" tab.
  • Check the box next to "Run this program in compatibility mode for" and select an older version of Windows. Try running the installer again.
  • Check BIOS Settings:
  • Ensure that the IDE controller is properly detected in the BIOS settings. Check if the controller is enabled and configured correctly.
  • Check IDE Cable and Power Connection:
  • Make sure that the IDE cable and the power connections to the DVD drive are secure. A loose connection can prevent the drive from being recognized.
  • Device Manager Troubleshooting:
  • In Device Manager, right-click on the IDE controller and select "Uninstall device." Then restart your computer to allow Windows to reinstall the driver automatically.
  • Verify Drive Recognition in BIOS:
  • Check if the DVD drive is recognized in the BIOS. If it's not detected here, it might be a hardware issue or connection problem.
  • Check Drive Compatibility:
  • Ensure that the lightscribe DVD drive is compatible with Windows 7. Some older drives might have compatibility issues with newer operating systems.
Once you have gone through these steps, you should be able to resolve the issue of Windows 7 not recognizing your DVD drive connected to the IDE controller. If the issue persists, feel free to provide more details for further assistance.​
