The original poster is experiencing USB port power issues on their Gateway NV55c after upgrading to Windows 8, where devices only work when connected through a powered USB port expander. They believe it may be a driver or setting problem, as devices directly connected to USB ports are not recognized or powered. A respondent suggests trying drivers from the manufacturer's website, including older Windows 7 versions in compatibility mode, but the problem persists, indicating a likely configuration or driver compatibility issue with Windows 8.
jayram1408
I have a Gateway NV55c. I had no problems with windows 7. I am running Windows 8 9600 build now. My USB ports will not work unless I have a powered expansion port plugged in. It's as if they are not getting power, how ever, I check the settings in the device manager and it says they have power. I believe this may be a driver issue. Any help would be appreciated.
I checked your manufacturers web page and drivers can be found here:
Try using the windows 7 versions first and if you have a problem use compatibility mode.
jayram1408
Thread Author #3
I have all the drivers installed. Its a setting, driver or something else. I can get my computer to recognize and install drivers and use any device, as long as it is plugged into a self powered USB port expander. The expander will work on any of the 3 USB ports. Any device not run thru the powered expander will not be recognized, or power up. Any device plugged into the expander works just fine. I can plug in my small keyboard light in any USB port and it lights up though. I'm at a loss. Windows 8 Enterprise N (x64) build 9200.win8_gdr.120926-1855
