GadgetJim57 inquires whether a RAVPower 32000mAh battery pack is safe to use with his Dell Inspiron 5770 laptop, seeking advice on compatibility. Neemobeer clarifies that USB power banks are generally designed to charge smaller devices and not suitable for directly charging laptops. Subsequently, GadgetJim57 reports finding alternative, higher-capacity power packs specifically designed for laptops and other devices, without confirming if he intends to purchase them.
GadgetJim57
Active Member
Would a RAVPower 32000mAh battery pack be safe to use with my Dell Inspiron 5770 laptop ?
As in to charge your laptop? In that scenario no a laptop can't charge from a usb port. The battery pack is meant to charge devices that receive power through a usb/thunderbolt port.
Neemobeer
Windows Forum Team
GadgetJim57
Active Member
Thread Author #3
I think I found the battery packs that I need for my laptop and other devices:
*** Crave PowerPack CRVPP101 50000mAh = $150.00
>>> Link Removed
*** Chafon Portable Generator 155WH/42000mAh Battery Backup Pack Power Source = $134.00
>>> Link Removed
