Allanstech
I installed RC1 no problem. My system has two printers (Epson CX5900 inkjet as default and HP Laserjet 3030 Multifunction as secondary). I shared the Epson on the home network and my other PCs and laptops can print to it, but when I tried to share the Laser as well there is no sharing available. Anyone else have this problem?
How about running setup for the laser on another computer and during install you will have the option to select the Network printer. you can either browse or search the network or enter the UNC path to your main computer like this:
\\computer_name\Printer_name
reghakr
How about if you choose properties?
Is the Sharing tab there?
Allanstech
If I choose Properties then I get a box with 2 tabs - General and Hardware. Neither Tab or any inside them has a sharing function enable. I should mention that this printer is on LPT1. The default printer is on USB.
reghakr
How about you select the printer, choose File > Server proprties and see if any info here might help.
Allanstech
N othing in there either. I reinstalled the printer using a USB port but still no joy. I can't find any information in the help section (they're still writing it apparently) which refers to sharing and it looks as if I am stuck with the problem until MS gets around to fixing it.
Thanks for your assistance....Jim
reghakr
