The thread discusses issues with Sigmatel audio drivers on various Dell laptops, especially after upgrading to Windows 7, with users experiencing non-functional or problematic audio input/output and driver installation challenges. Several contributors share their experiences, including unsuccessful driver updates, uninstallation difficulties, and workarounds such as using different headsets or waiting for Dell's official driver updates. Overall, the sentiment indicates ongoing frustration among users due to driver support delays, but some find temporary solutions through workaround methods or hardware adjustments.
U
Unregistered
Guest
well i downloaded the right audio driver on my pc! because i have a sigmatel STAC92XX C-Major HD Audio card
and i have a dell pc so i went to dell and downloaded the latest driver but IT DOESNT WORK!
although when i went to configure in my audio settings and it did the audio test it did come out my rear, center, and sub probably no one can help its probably just the driver itself... but don't go telling me its vista capable when its not... SigmaTel pulled a nVidia!
but if anyone can give me a suggestion or a website i would appreciate it
Sigmatel Driver for Dell Notebooks (XPS M1530), workarounds
I upgraded from Vista Ultimate to Windows 7 on my Dell XPS M1530 after religiously uninstalling everything that Microsoft Windows 7 Upgrade Advisor even hinted might cause trouble (Fortunately I was able to use a cloned drive with no MS beta SW installed -- no luck otherwise! ).
Beautiful and stable EXCEPT for the Sigma Tel High Definition Audio CODEC - nothing worked even though Windows said I had the best driver for this device. DELL driver download site said otherwise so I ran their recommended R190517.EXE to install Driver Version 6.10.0.5866 (2/15/2008) - for Vista, which is all Dell tech support vouches for now (except on new machines with Windows 7...
U
Unregistered
Guest
Thread Author #2
Similar problem
I'm having some issues with the same driver downloaded from Dell. I use Ventrilio voice chat for gaming and one day the input up and decided to stop working. Because the output worked fine I assumed it was an issue with the cheap headset I bought, so I went and got another...same problem. I google the problem, find the CORRECT driver from dell for the E1505, and now I have no audio what-so-ever. Anyone have any suggestions?
U
Unregistered
Guest
Thread Author #3
i can't even uninstall it
the sigmatel driver on my E1505 messed up and now i can't uninstall it at all, i don't feel like doing another reformat or anything...any suggestions?
U
Unregistered
Guest
Thread Author #5
I have the same problem on a dell xps M1530. The driver that I downloaded form dell is not working with livemeeting. Any ideas? Thanks!
U
Unregistered
Guest
Thread Author #6
IF YOU HAVE A SIGMETEL DRIVER YOU SHOULD GET A DIFFERENT SOUND CARD XD they dont work for squat
disumia
i just got off the phone with dell and my company works with them alot. they stated that they do not support windows 7 yet and will not have any drivers that work correctly till end of october. from what i understand they havent even started to create proper drivers for this system yet.
ai2ez4me
similar problem
I have a dell XPS 1530 with a sigmatel audio card and the driver that I downloaded from dell is not working.
The C-major audio driver that I need for my sound card is not working, I hope that dell will release something to fix that
problem on windows 7.
Meanwhile if anybody find something about this issue, he would more than welcome to post is solution over here.
tomsailor
Beautiful and stable EXCEPT for the Sigma Tel High Definition Audio CODEC - nothing worked even though Windows said I had the best driver for this device. DELL driver download site said otherwise so I ran their recommended R190517.EXE to install Driver Version 6.10.0.5866 (2/15/2008) - for Vista, which is all Dell tech support vouches for now (except on new machines with Windows 7 preinstalled).
This driver upgrade fixed everything EXCEPT the headset-microphone jack input: The Jack Setup pops up with "Microphone" pre-selected instead of the correct question-mark selector, but it's clear from exhaustive analysis (going through the Manage Audio Device settings and corresponding application settings, e.g., Skype 4.1->Audio-Settings->Advanced Options) that even if you re-select "Microphone" in the Sigmatel Jack popup, all you've really accomplished is to turn off the notebook's built-in Microphone Array. At least you can unplug the mike and still use your headset with the built-in microphone array.
Another option (for the all-headset purist with background noise) is to use a USB headset (digital i/o with built-in audio CODEC), or a USB adaptor that's compatible with your 3.5 mm audio-jack headset (pay attention to whether the mike jack is stereo or mono); at least I can vouch for the iHome Lifetalks USB foldable headset that I picked up for this test. It includes an audio headset with two 3.5 mm stereo plugs and a USB-adaptor whose mike jack does NOT work with the mono-mike-jack headset that I was using with Vista.
That's about it for now. Otherwise I am happy as a clam with Windows 7, using Acronis True Image 2010 for cloning and backups (leaving True Image 2009 installed wrecked an earlier upgrade attempt just as Upgrade Advisor promised🙂.
--When I plugged in my Windows Mobile phone to a USB port the Sync Center "driver" (replacing the pre-upgrade uninstalled Windows Mobile Device Center 6.1) was automatically downloaded and installed.
--Ubuntu 9.10 is running on a (free) VMWare Player 3.0 virtual machine fully integrated with Windows 7 (full windows, shared folders and devices, cut and paste across guest-host). Player's Easy Setup option to create a new VM from the Ubunto-iso image in the virtual CDROM is amazing (Look Ma, almost no hands); you can even specify how many CPUs you want it to use.
astavee
Hi everyone. I had the same problem with my XPS1530 after I installed Windows 7 32bit. Fortunately, I can skype n voice chat since I bought logitech headset which came with usb connection. What really amaze me, this line in problem doesn't occur when I switch to Windows 7 64bit.
leoman
Well-Known Member
Here is the link to download correct driver for it to fix issue from dell: (even this driver is suport for windows vista but it does works for windows 7, after installation you must restart the computer to make it work:
Link Removed - Invalid URL
NOTE: AFTER downloading the file done, you should right click on the download file and click on property then select compatiblility then force it run with windows vista then put the check in the box run as adminstrator also then it's ready to run installation.
mumtazkhan
Active Member
I have a Windows 7 PC utilized just disconnected in my home/office and utilized around 1 to 2 hours daily with the exception of most Sundays and at assess time and Link Removed as well. It's 3 years of age, just the default defragger is as a result and I've never observed any rate more noteworthy than 1% fracture for my OS segment and 0% for my information segment.
