hot dog
My USB Floppy Drive was working fine in Windows Vista Business.
After installing Windows 7 Beta, and plugging in the my USB Floppy Drive, Windows fails to install the driver for it. It shows up in Device Manager, but the driver will simply not install...
:D thanks
lol...
There is one other solution I thought of.....don't know why I didn't try it before, I guess I was just lazy.
Anyway, I have the OEM driver that came with the USB drive. It might be more compatible than the driver that Windows is attempting to install....
I'll give it a try and let you know what happens...
alright, well I'm tired of messing with it...
the "add hardware" feature will not pick up the USB drive, and when I try pointing the wizard to the DVD rom drive with the driver, Windows tells me that the driver is not compatible and to make sure the driver is "32-bit" driver........I'm not going to waste any more time with it.........I'll just send Microsoft my two cents of comments and see what happens....
john3347
Fantastic Member
I have a similar problem with my internal 3.5 floppy. Windows recognizes the drive, but doesn't recognize a disc that is known to be a good disc when inserted. The drive worked normally prior to windows 7 installation.
hot dog
looks like we've got no other choice than to use the "Send Feedback" option on the Window 7 desktop and tell Microsoft what we think.......most likely, many others are having the same issue
john3347
Fantastic Member
You are correct, Hot Dog. I have reported my symptoms through the feedback shortcut. There is, however, no return feedback from Microsoft concerning solutions to any issues reported there. I just wondered if anyone on this forum was having the same problems and if they had found any workarounds. I have read that they (Microsoft) have already received more than 500,000 responses through the "send feedback" channel. I wonder how many different issues are encompassed by these 500,000 responses.
hot dog
lol...
