The thread discusses two related USB issues on Windows: a USB-C hub whose Type-C plug causes an HDMI monitor to briefly sleep/blank when the connector is only touching, and later reports about Windows detecting a USB device but failing to read it. The main answers argue the first problem is likely hardware-level (grounding/ESD transients, EMI/shielding, and/or hub/HDMI cable/power-strip design) rather than a Windows “setting,” recommending practical tests like moving/separating cables, swapping HDMI cables, using the same power strip, and trying different USB ports/hubs. Overall sentiment is helpful and troubleshooting-oriented, with contributors converging on restart/full shutdown and electrical/interference checks, and no strong indication of widespread Windows bugs beyond these symptoms.
mccmw
Member
I think this is the best forum to post this🙂 If not, let me know and I'll try to move or re-post. I have a USB 3.1 Gen 2 Hub with 6 Type A and 4 Type C ports. It is externally powered (AC adapter). For some reason, when a Type C connector is about to be connected (almost or just touching but not inserted yet), it triggers my HDMI monitor to "sleep." Movement of the mouse turns it back on, and the USB device usually connects properly. I've never encountered this behavior before.
Can someone explain what is causing this bug and if there is some setting or other to remedy it? Thanks.
Hi mccmw,
Yes, this is a reasonable place to ask it.
What you’re describing does not sound like a normal Windows “setting” issue. Because it happens when the USB-C plug is only just touching the port, the most likely cause is electrical interference, not software.
What is probably happening​
When the USB-C shell gets close to or first touches the hub, one of these usually happens:
  • Ground equalization / tiny discharge
  • The hub, PC, monitor, and power adapter may be sitting at slightly different ground potentials.
  • The moment the connector shell touches, that difference equalizes.
  • That brief transient can disturb the HDMI link long enough for the monitor to think the signal disappeared...
Hi mccmw,
  • EMI / shielding problem
  • USB 3.x devices and hubs can generate a lot of high-frequency noise.
  • If the hub or HDMI cable shielding is weak, the HDMI signal can drop for a moment.
  • The monitor then goes black or enters sleep because it briefly loses sync.
  • Hub hardware or power design issue
  • Some hubs are just poorly designed.
  • An externally powered hub with marginal grounding or filtering can cause odd behavior exactly like this.
The key clue is this:
  • If the monitor blanks before the device is fully inserted, Windows is probably not the trigger.
  • That points to hardware-level electrical noise, grounding, or cable shielding.
Most likely fixes​
Try these in order, from easiest to most useful.
1. Move the hub away from the HDMI cable and monitor cable​
  • Place the hub as far from the HDMI cable and monitor as practical.
  • Make sure the USB-C plug and hub are not physically brushing the HDMI cable.
  • Test again.
If this helps, the problem is likely EMI coupling.
2. Try a different HDMI cable​
  • Replace the HDMI cable with a shorter, better-shielded one.
  • If you have one, use a cable with ferrite chokes.
  • Test the same USB-C connection again.
A weak HDMI cable is a very common cause of brief signal dropouts.
3. Plug the hub power adapter and monitor into the same power strip​
  • Shut everything down.
  • Plug the PC, monitor, and hub power brick into the same surge protector/power strip.
  • Power back on and test.
This can reduce ground potential differences between devices.
4. Test a different USB port path​
  • Connect the hub to a different USB port on the PC.
  • If possible, try a rear motherboard port instead of a front-panel port.
  • Test again.
Front-panel ports and some internal headers are more susceptible to grounding/noise issues.
5. Try the monitor on a different input​
  • If your monitor and PC support it, test with DisplayPort instead of HDMI.
  • If not, try another HDMI input on the monitor.
  • Test the hub again.
DisplayPort sometimes tolerates this kind of disturbance better than HDMI on a given setup.
6. Disconnect the hub’s AC adapter briefly and test​
  • Power off the hub if needed.
  • Disconnect the hub’s external power supply.
  • Test with a low-power USB device only.
  • Do not do this with devices that need the hub’s external power.
If the behavior changes, the external power supply or grounding through it is likely involved.
7. Try a different USB-C cable/device​
  • Test with another USB-C cable.
  • Test with another USB-C device.
  • See whether the screen blanks with every device or only one.
If it only happens with one cable/device, that cable or device may be leaking noise into the connection.
Windows settings to check​
Because this happens on near contact, I would treat Windows as a secondary suspect. Still, you can try these:
1. Disable USB selective suspend​
  • Open Control Panel.
  • Go to Power Options.
  • Click Change plan settings.
  • Click Change advanced power settings.
  • Expand USB settings.
  • Set USB selective suspend setting to Disabled.
  • Restart and test.
2. Update GPU and chipset drivers​
  • Install the latest graphics driver from NVIDIA, AMD, or Intel.
  • Install the latest motherboard chipset/USB drivers from your system or board vendor.
  • Restart and test.
This may help if the HDMI link recovery is overly sensitive, but again it probably will not fix the root cause if the issue happens at first touch.
What I suspect most​
My best guess is:
  • A grounding or ESD transient from the powered USB hub
  • Combined with
  • An HDMI link that is sensitive to a momentary disturbance
So I would focus first on:
  • Same power strip for all devices
  • Better / shorter HDMI cable
  • Greater physical separation between hub and video cabling
  • Testing another hub or another power adapter if available
Strong clue: this may be a hub quality issue​
If none of the above changes anything, the hub itself may simply be the culprit.
A good test is:
  • Borrow or try another externally powered USB-C/USB 3.x hub.
  • Recreate the same setup.
  • If the monitor no longer blanks, your current hub is almost certainly the cause.
What to report back​
If you want, reply with these details and I can narrow it down further:
  • Your PC or motherboard model
  • Your monitor model
  • Whether the display is connected by HDMI directly from the GPU or from the motherboard
  • The brand/model of the USB hub
  • Whether this happens with all USB-C devices or just one
  • Whether it still happens if the hub’s power brick is unplugged
At the moment, though, I would not call this a Windows bug first. It sounds much more like a hardware interference/grounding issue.
Hi Adler144, it sounds like Windows is detecting that a USB device is connected, but it cannot properly read the device or its contents. That can be caused by the USB device, the USB port/hub, the file system, or a driver/power issue.
First checks​
  1. Try a different USB port
    • If you are using a hub, plug the USB device directly into the PC.
    • Prefer a rear motherboard USB port on a desktop PC.
  2. Try the USB device on another computer
    • If it fails there too, the USB device may be corrupted or failing.
    • If it works there, the issue is likely with this PC, hub, port, or driver.
  3. Check Disk Management
    • Press Win + X.
    • Click Disk Management.
    • Look for the USB drive.
    • Check whether it appears as RAW, Unallocated, No Media, or without a drive letter.
  4. Assign a drive letter if missing
    • In Disk Management, right-click the USB volume.
    • Choose Change Drive Letter and Paths.
    • Click Add.
    • Pick a letter such as E: or F:.
    • Click OK.
If Windows says it needs to format the USB​
Do not format it if you need the files. Formatting may make recovery harder.
Instead:
  1. Open Command Prompt as Administrator.
  2. Run:
chkdsk X: /f
Replace X: with the USB drive letter.
Example:
chkdsk E: /f
If the USB shows as RAW or unreadable​
That usually means the file system is damaged.
  1. Do not format yet if the files are important.
  2. Try data recovery software first.
  3. After recovering files, you can reformat the USB drive.
Check Device Manager​
  1. Press Win + X.
  2. Open Device Manager.
  3. Expand Disk drives and Universal Serial Bus controllers.
  4. Look for warning icons.
  5. Right-click the USB device and choose Uninstall device.
  6. Unplug the USB device.
  7. Restart the PC.
  8. Plug the USB device back in.
Disable USB power saving​
  1. Open Device Manager.
  2. Expand Universal Serial Bus controllers.
  3. Right-click each USB Root Hub or Generic USB Hub.
  4. Click Properties.
  5. Go to Power Management.
  6. Uncheck Allow the computer to turn off this device to save power.
  7. Click OK.
Important question​
When you say the system “couldn’t read it,” what exactly happens?
Please tell us:
  • Is this a USB flash drive, external hard drive, phone, or another device?
  • Does it show in File Explorer?
  • Does it show in Disk Management?
  • Do you get an error like “You need to format the disk”, “USB device not recognized”, or “Access is denied”?
  • Are you connecting it through the USB hub mentioned in this thread, or directly to the PC?
If this is happening through the same powered USB hub, I would test the USB device directly connected to the PC first. That will tell us whether the hub is part of the problem.
Adler144
Well-Known Member
I suggest that! Try to avoid that long time on hibernate your device sometimes the device needs to be restart or shut down before use. Maybe some updates are coming
Good point, Adler144.
Long hibernate or sleep sessions can sometimes leave USB controllers, hubs, or connected devices in a bad power state. A full restart or shutdown can reinitialize the USB controller and clear odd detection/read problems.
Suggested quick test​
  1. Save your work.
  2. Disconnect the USB device or hub.
  3. Restart the PC using:
Start > Power > Restart
  1. After Windows loads fully, plug the USB device directly into the PC.
  2. If it works, then reconnect through the hub and test again.
Also check Windows Update​
  1. Open Settings.
  2. Go to Windows Update.
  3. Click Check for updates.
  4. Install any pending updates.
  5. Restart again if Windows asks.
One extra note​
If the PC uses Fast Startup, a normal shutdown may not fully reset hardware. If USB problems keep returning, try a true full shutdown:
shutdown /s /f /t 0
Then turn the PC back on manually.
So yes — restarting after long hibernate/sleep periods is a good troubleshooting step, especially when USB devices are detected but not readable.
Adler144
Well-Known Member
Absolutely agree with you AI. Try this and everything will be set and done without troubleshooting lack
Thanks, Adler144 — agreed, a restart/full shutdown is often the quickest thing to try first.
That said, for the original issue in this thread — the HDMI monitor sleeping when the USB-C connector is only just touching the hub — I would still keep hardware/electrical interference or grounding high on the suspect list.
Simple order to try​
  1. Restart the PC.
  2. Disconnect the USB hub power adapter for 30 seconds.
  3. Plug the hub back in.
  4. Connect the USB device after Windows is fully loaded.
  5. If the monitor still blanks, test the hub on a different USB port.
  6. If possible, try a different HDMI cable or plug the monitor and hub into the same power strip.
A restart can clear USB controller glitches, especially after sleep or hibernate. But if the monitor reacts before the USB device is even fully inserted, that usually points more toward ESD, grounding, shielding, or hub/cable quality than a normal Windows software problem.
