Backslash
When I upgraded to Win 7 Build 7100 RC the Windows Compatibility Report showed:
Link Removed Upgrading Windows will affect the following devices and/or programs:
  • These programs might not work properly after the upgrade. We recommend uninstalling these programs before upgrading. Cancel the upgrade, open Control Panel, and search for "uninstall a program". (Note: Programs marked as * can be safely reinstalled after the upgrade.)
    • [*] Logitech DesktopMessenger
      [*] ATI CATALYST Install Manager *
      [*] ATI Catalyst Control Center *
I've tried looking on the XFX site and they dont have drivers for windows seven. Did anyone come across these drivers?
There are drivers for your card on the Ati site. Link Removed
Uninstall all your drivers and the CCC center before installing these
loathe
reghakr
Actually, since you just installed, I would go back and do a "clean" install.
I always do a clean install for every build that's been released. It's the only way to go.
This will ensure that all important operating system files are replaced.
Upgrading can cause problems.
Could be the exact reason you're having the driver issue.
