Pranoti
Hi.
I have encountered a problem in which all applications are opening as a media player file. Whenever i open any application such as picasa, the vlc media player gets opened.
I tried using the restore defaults option, but it did not work. Even with inbuilt applications such as notepad, the same occurs.
Can anyone suggest a solution please.?
Thanks.
Hello and welcome to the forum.
Sounds like your file associations for your executables are messed up.
Grab the EXE fix from here Link Removed - Invalid URL
And read the instructions on that page for proper use of the fix.
Regards
Randy
Drew
Banned
Hi & Welcome
> Set Default Programs
If you need more guidance from there, come on back
Cheers,
Drew
Pranoti
I tried doing that. Changed it to show icons and notifications...isnt working...
Trouble
Noob Whisperer
Regards
Randy
