albinramone
CADA VEZ QUE INICIO UN JUEGO A LOS 5 MIN SE CONGELA
Y EL EVENT LOG ME DICE ESTO
Log Name: System
Source: Microsoft-Windows-Kernel-Power
Date: 2/10/2010 11:41:28 AM
Event ID: 41
Task Category: (63)
Level: Critical
Keywords: (2)
User: SYSTEM
Computer: AlbinRAMONE-PC
Description:
The system has rebooted without cleanly shutting down first. This error could be caused if the system stopped responding, crashed, or lost power unexpectedly.
Event Xml:
<Event xmlns="Link Removed due to 404 Error">
<System>
<Provider Name="Microsoft-Windows-Kernel-Power" Guid="{331C3B3A-2005-44C2-AC5E-77220C37D6B4}" />
<EventID>41</EventID>
<Version>2</Version>
<Level>1</Level>
<Task>63</Task>
<Opcode>0</Opcode>
<Keywords>0x8000000000000002</Keywords>
<TimeCreated SystemTime="2010-02-10T16:11:28.644429900Z" />
<EventRecordID>7346</EventRecordID>
<Correlation />
<Execution ProcessID="4" ThreadID="8" />
<Channel>System</Channel>
<Computer>AlbinRAMONE-PC</Computer>
<Security UserID="S-1-5-18" />
</System>
<EventData>
<Data Name="BugcheckCode">10</Data>
<Data Name="BugcheckParameter1">0xf2</Data>
<Data Name="BugcheckParameter2">0x2</Data>
<Data Name="BugcheckParameter3">0x1</Data>
<Data Name="BugcheckParameter4">0xfffff80002a9bb2e</Data>
<Data Name="SleepInProgress">false</Data>
<Data Name="PowerButtonTimestamp">0</Data>
</EventData>
</Event>
SOLO CUANDO JUEGO! SALE ESE ERROR SE CUELGA EL PC
QUE PODRA SER?
su ayuda seria de gran utilidad gracias!
cybercore
Por lo que ando viendo es un problema de hardware o drivers. Prueba el controlador de vídeo más recientes.
