The thread discusses a recurring issue with a Windows PC restarting unexpectedly due to Kernel Power 41 errors. The original poster has had the PC checked multiple times, with repair services unable to identify a fault, and has explored potential causes like power options and system logs. Contributors suggest that hardware issues, particularly with the power supply, are likely, and note that some system event errors are normal or unrelated, emphasizing the randomness of the restarts despite electrical checks.
kane2007uk
hi
my pc has started to restart due to a Kernel power 41
been in a pc repair and was told that there was nothing wrong with pc
and had been in for repair 3 times last time was for just over 2 weeks and was told the same they never witnessed to pc restart
this is the log I think
- <System>
<Provider Name="Microsoft-Windows-Kernel-Power" Guid="{331C3B3A-2005-44C2-AC5E-77220C37D6B4}" />
<EventID>41</EventID>
<Version>4</Version>
<Level>1</Level>
<Task>63</Task>
<Opcode>0</Opcode>
<Keywords>0x8000400000000002</Keywords>
<TimeCreated SystemTime="2017-04-24T09:57:43.618475000Z" />
<EventRecordID>12364</EventRecordID>
<Correlation />
<Execution ProcessID="4" ThreadID="8" />
<Channel>System</Channel>
<Computer>DESKTOP-HUM1SCS</Computer>
<Security UserID="S-1-5-18" />
</System>
- <EventData>
<Data Name="BugcheckCode">0</Data>
<Data Name="BugcheckParameter1">0x0</Data>
<Data Name="BugcheckParameter2">0x0</Data>
<Data Name="BugcheckParameter3">0x0</Data>
<Data Name="BugcheckParameter4">0x0</Data>
<Data Name="SleepInProgress">0</Data>
<Data Name="PowerButtonTimestamp">0</Data>
<Data Name="BootAppStatus">0</Data>
<Data Name="Checkpoint">0</Data>
<Data Name="ConnectedStandbyInProgress">false</Data>
<Data Name="SystemSleepTransitionsToOn">0</Data> i7 4790
<Data Name="CsEntryScenarioInstanceId">0</Data>
</EventData>
</Event>
specs of pc
i7 4790
z97 pro
Titan X
corsair vengeance ram 4x 8gig sticks
corsair 780 psu
Samsung ssd 850 evo 500g
any help tried the power options that ppl say still get the Kernel power
thx in advance
3x wd wd30purx-64p6zy0
Well the power button timestamp is 0 so it's not detected the power button being held down. I would look at the System event log and filter for User32 events. Look through those and see if anything is initiating a shutdown which is probably doubtful when your problem occurs since they are considered clean shutdowns. More likely this is a hardware issue with the power supply and unless it's completely failed a pc tech won't be able to tell you that.
Neemobeer
Windows Forum Team
kane2007uk
Thread Author #3
just looking through the system logs and there are these that say error
<Provider Name="Microsoft-Windows-DistributedCOM" Guid="{1B562E86-B7AA-4131-BADC-B6F3A001407E}" EventSourceName="DCOM" />
<EventID Qualifiers="0">10016</EventID>
<Version>0</Version>
<Level>2</Level>
<Task>0</Task>
<Opcode>0</Opcode>
<Keywords>0x8080000000000000</Keywords>
<TimeCreated SystemTime="2017-04-14T01:34:28.536133200Z" />
<EventRecordID>5602</EventRecordID>
<Correlation />
<Execution ProcessID="992" ThreadID="6880" />
</System>
- <EventData>
<Data Name="param1">application-specific</Data>
<Data Name="param2">Local</Data>
<Data Name="param3">Activation</Data>
<Data Name="param4">{D63B10C5-BB46-4990-A94F-E40B9D520160}</Data>
<Data Name="param5">{9CA88EE3-ACB7-47C8-AFC4-AB702511C276}</Data>
<Data Name="param6">NT AUTHORITY</Data>
<Data Name="param7">SYSTEM</Data>
<Data Name="param8">S-1-5-18</Data>
<Data Name="param9">LocalHost (Using LRPC)</Data>
<Data Name="param10">Unavailable</Data>
<Data Name="param11">Unavailable</Data>
</EventData>
</Event>
and this Warning
Provider Name="Microsoft-Windows-Kernel-PnP" Guid="{9C205A39-1250-487D-ABD7-E831C6290539}" />
<EventID>219</EventID>
<Level>3</Level>
<Task>212</Task>
<Opcode>0</Opcode>
<Keywords>0x8000000000000000</Keywords>
<TimeCreated SystemTime="2017-04-13T21:36:08.624724700Z" />
<EventRecordID>5502</EventRecordID>
<Correlation />
<Execution ProcessID="4" ThreadID="136" />
</System>
- <EventData>
<Data Name="DriverNameLength">24</Data>
<Data Name="DriverName">ACPI\PNP0A0A\2&daba3ff&0</Data>
<Data Name="Status">3221226341</Data>
<Data Name="FailureNameLength">14</Data>
<Data Name="FailureName">\Driver\WUDFRd</Data>
<Data Name="Version">0</Data>
</EventData>
</Event>
kane2007uk
Thread Author #4
I also seen this
[ Name] User32
[ Guid] {b0aa8734-56f7-41cc-b2f4-de228e98b946}
[ EventSourceName] User32
- EventID 1074
[ Qualifiers] 32768
Version 0
Level 4
Task 0
Opcode 0
Keywords 0x8080000000000000
- TimeCreated
[ SystemTime] 2017-04-24T13:44:36.403626800Z
EventRecordID 13020
Correlation
Execution
[ ProcessID] 576
[ ThreadID] 2512
Channel System
Computer DESKTOP-HUM1SCS
- Security
[ UserID] S-1-5-21-3940922178-1144428469-1201000883-1002
- EventData
param1
C:\WINDOWS\Explorer.EXE (DESKTOP-HUM1SCS)
param2 DESKTOP-HUM1SCS
param3 Other (Unplanned)
param4 0x0
param5 power off
param6
param7
DESKTOP-HUM1SCS\mick
could this be the root of my problem
Neemobeer
Windows Forum Team
No, the first 2 errors are fairly normal and the last event is a shutdown initiated by you.
kane2007uk
Thread Author #6
k
