ibonehj
well this how it goes..
my task manager and regedit were disabled by administrator..
what shall i do to help me get back my task manager and regedit..
did try the procedures for enabling regedit..still doesnt work..
also, used online virus scanners..not a big help..installed SuperAntiSpyware..didnt gave me a good hand. but HiJackThis found this "O7 - HKCU\Software\Microsoft\Windows\CurrentVersion\Policies\System, DisableRegedit=1"..fixed it with HiJackThis..but every time i restart my system..same results !!
i really dont know what to do..i scanned my system using AVIRA(current av)..i dont know why but my system is now lagging..
i really need a hand.. i dont want to end up reinstalling again..
Elmer
Hi ibonehj and Welcome to the Forum,
Download, install and update Malwarebytes' Free. Run a full scan in Safe Mode.
After running this, run sfc /scannow to check your system files.
Let us know how it goes.
ibonehj
thanks !!
i am about to start download malwarebytes..
then i'll post out the results after
ibonehj
whoa!!
good god !!
its now enabled !!
malwarebytes removed this:
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Policies\System\DisableTaskMgr (PUM.Hijack.TaskManager)
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Policies\System\DisableRegistryTools (PUM.Hijack.Regedit)
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\AntiVirusDisableNotify (PUM.Disabled.SecurityCenter)
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\FirewallDisableNotify (PUM.Disabled.SecurityCenter)
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\UpdatesDisableNotify (PUM.Disabled.SecurityCenter)
c:\kxatw.exe (Malware.Packer.Gen)
c:\Users\barruga\downloads\heaventools.pe.explorer.v1.99.r6.incl.keygen.and.patch-brd\keygen.and.patch\Keygen.exe (Riskware.Tool.CK)
c:\Users\barruga\downloads\heaventools.pe.explorer.v1.99.r6.incl.keygen.and.patch-brd\keygen.and.patch\Patch.exe (Riskware.Tool.CK)
d:\e-games\cabal online (ph)\dp1.fne (Worm.Autorun)
d:\e-games\cabal online (ph)\krnln.fnr (Worm.Autorun)
i'll report back again after restarting coz if experienced this before then after restarting..removed wares are back again..
again thanks elmer !!
this is great..
finished restarting my system now !!
guess what..my system now is almost back to normal...
thanks for the 3rd time..
ibonehj
5 hours ago..
well i said twas already fine though.
atm..my system has blocked my regedit and taskmgr again !!!!
hhhmmm..is there any ways that i can clear up this problem ??
damn..why am i having this kind of problem..
4:20am (UTC +8)
waiting for any replies before resorting to os re-installation..
:frown::frown:
