rolloroy
Well-Known Member
i use vso convert x to dvd program will covert project but will not burn the project i recieive an error message about half way through burn does any one else have similar. problems
OldTimer
Banned
For anyone wanting to help......... it would be good to know some particulars, like:
What computer? (Desktop or laptop.)
OS, version?
What speed are you trying to burn at?
Have you used the same burner and software under XP, Vista or win-7?
Always remember, "A slower burn is a better burn".
I use only two programs for burning DVD's on my computer.
"Nero", which I've used like, , , FOREVER!
and "ImgBurn" which I only use for burning .ISO files to CD or DVD.
It also works great for making an ISO off of a CD or DVD.
Cheers Mate!
:cool:
