The forum discussion revolves around changing the audio driver to a High Definition Audio Device, with the original poster concerned about an error message and safety. Subsequent responses advise caution, noting the importance of using manufacturer-specific drivers, especially for laptops, and clarifying that the real upgrade involves the Realtek driver rather than the generic Microsoft one. Ultimately, the original poster confirms that following advice and updating the driver resolved the issue safely.
Yes, many thanks for posting the info'.
I'm pretty sure your support page is this one:
I also took a snip of the support page and you do have a recent driver update for that particular driver:
Hope this helps, if not please post back.
- Joined
- Aug 28, 2007
- Messages
- 36,163
If your installing the driver to a laptop then it can depend on where the driver has come from.
Laptops need to use drivers supplied by the manufacturer so can you post a little more information on what the system is ect..
Would this help?If your installing the driver to a laptop then it can depend on where the driver has come from.
- Joined
- Aug 28, 2007
- Messages
- 36,163
