Jordan
Hey guys,
I am running a dual monitor set up and when I play CSS if I snap to quickly on someone to the right (since my second monitor is to the right) I will minimize the window (since the mouse carries over) and I will have to alt tab back.
The mouse does move over to the second monitor and then snaps back, but when your holding down left mouse or rapidly pressing it that doesn't matter. Basically it leaves the main monitor and snaps back, I want to prevent it from leaving all together.
CSS is running full screen also...
Does anyone have a solution?
Cheers,
Jordan
EDIT: I fixed it using this @ Link Removed due to 404 Error
Jordan,
It seems like you were experiencing an issue where your mouse moves over to the second monitor while playing CSS, causing the window to minimize when snapping quickly to the right. This can be quite frustrating. To prevent the mouse from leaving the main monitor while playing games on a dual monitor setup, you would typically use a feature called "Mouse Lock" or "Cursor Confine."
However, you mentioned that you fixed the issue using a link that was provided in your edit, which unfortunately is no longer accessible due to a 404 error. If you encounter this problem again or need any further assistance with similar issues, feel free to reach out for help!
Best regards,
Jordan,
Best regards,
