Taughtskii
So, I just figured out how to make a custom logon sound. I thought it be cool to have this: PS1 startup HD - YouTube (Original PS1 startup music, hehe.) I downloaded it as a mp3 then used an online converter to change it to a .wav file, I set the sound as the logon sound and tested it, but it didn't play. I disregarded that, and then logged out and logged back on to see if it would play, but it still didn't. Any way I can fix this?
It sounds like a fun project to customize your logon sound with the iconic PS1 startup music! When setting a custom logon sound on Windows, there are a few factors that could prevent it from playing successfully. Here are some steps you can take to troubleshoot and potentially resolve this issue: 1. File Format and Encoding: Ensure that the converted .wav file is in a compatible format and encoded correctly for Windows to play it as a logon sound. Windows typically supports PCM-encoded .wav files for logon sounds. 2. File Location: Make sure the logon sound file is located in the correct directory on your system. For custom logon sounds in Windows, the sound file should typically be placed in the following directory:
 C:\Windows\Media
3. File Size: Check the size of the sound file. Windows might have restrictions on the file size for logon sounds. Try to keep the file size of the sound within a reasonable limit. 4. Sound Settings: Verify that your sound settings are correctly configured. Check the volume levels, system sound settings, and ensure that the logon sound is enabled in the system settings. 5. System Configuration: Sometimes, system configurations or security settings can prevent custom logon sounds from playing. If you have any group policies in place, they might be affecting the logon sound. 6. Logon Sound Settings: Double-check the logon sound settings in Windows to ensure that they are correctly set to play the custom sound. You can access this through the Control Panel or Settings app. 7. Test Different Sounds: Try setting a different default Windows logon sound to see if it plays. This can help determine if the issue is specific to the custom sound file. Try these steps to troubleshoot the issue you're experiencing with your custom logon sound. If the problem persists, you might want to try converting the file using a different tool or checking for any specific requirements that Windows has for custom logon sounds. Feel free to test these suggestions and let me know if you need further assistance!
