The user anaylor01 seeks help disabling tap-to-click on a generic touchpad but reports that the usual Windows settings and options provided by the device manager are not available. Several users suggest checking device settings through Windows or contacting the manufacturer, but anaylor01 confirms no relevant options exist. The overall sentiment indicates difficulty in disabling tap-to-click due to limited available settings on the device.
you posted question regarding the touchpad and not touch-screen, anaylor01.
i would look at win-10 pc-settings … from there go to devices … then down to "mouse/touchpad" … finally, click "additional mouse options". this should bring up the mouse-properties interface.
study your mouse-properties interface and see if it allows you to disable the touchpad. for instance … mine offers the user to disable touchpad if a usb-mouse is attached. another feature my touchpad offers is temporarily disable … just by dbl-clicking in top-left corner … but this could be a proprietary toshiba feature.
you could also look in the...
Sonny
Fantastic Member
- Joined
- Nov 17, 2009
- Messages
- 1,386
pnamajck
Honorable Member
- Joined
- Aug 28, 2014
- Messages
- 433
anaylor01 … welcome to windowsforum.com … weekend is almost here.
pls indicate model-name/number of your computer … explain if you have upgraded any of the hardware … also detail what you have replaced the touchpad with (mouse or mouse/keyboard-combo) … also have you been doing all win-10 updates religiously?
someone will come along to advise/assist.
pnamajck
Honorable Member
- Joined
- Aug 28, 2014
- Messages
- 433
you could also look in the win-10 device-manager … probably would offer the same interface.
one other option … ask the manufacturer of your product … whereas they give you contact-info specific to your needs.. pls access their support-webpage at:
ref:
