Optiker
I am using 2 monitors. I like to be able to stream my cable through Microsoft Edge on one monitor and continue to do other work or web browsing on the other. However if I am interacting with the monitor that is not playing the video Microsoft edge acts as if it's running in the background and the video and audio stutters often and sometimes it gets to a point where they are out of synch. Is there any way to remedy this?
Go to Open Action Center->All Settings->System->Display and make sure that under the MULTIPLE DISPLAYS, you have it set to "EXTEND THESE DISPLAYS". Your video card should do the rest. I just tested this on my dell desktop PC, and am watching Deep Space Nine on Netflix via Edge full screen on my primary 24"monitor, while looking at MSN.com and reading news full screen on my 2nd monitor, a 20" display running Chrome. I also keep my Google Calendar up on that 2nd monitor for checking dates while E-mailing, making Hotel and travel reservations, etc. It works great! :fdance:
Please post back and LIKE this Post if this solution worked for you so we can share that information with our other forum...
ussnorway
Windows Forum Team
split the screen... this makes both sides 'active' at the same time
An image from 'Dual Monitor/Program Priority Issue'. First image shows a dual-monitor setup with a tech forum post on the right screen and red on the left. Second image shows another dual-monitor setup with a fish underwater on the left screen and a forum list on the right.
BIGBEARJEDI
Please post back and LIKE this Post if this solution worked for you so we can share that information with our other forum users who might have the same problem. Thanks.
<<<BIGBEARJEDI>>> :D
