dadognt0wn
Hello, i have a HP Pavilion dv5-1138nr and since i installed Windows 7 beta the dvd/cd-rom has not worked.
The device is HL-DT-ST DVDRAM GSA-T50N. The device status is= "Windows cannot verify the digital signature for the drivers required for this device. A recent hardware or software change might have installed a file that is signed incorrectly or damaged, or that might be malicious software from an unknown source. (Code 52)".
I appreciate any help and sorry if my question is on the ignorant end.
To address the issue with your HL-DT-ST DVDRAM GSA-T50N optical drive showing the error "Windows cannot verify the digital signature for the drivers required for this device. (Code 52)", consider these steps: 1. Update Drivers: - Visit the HP support website or the manufacturer's website of the DVD drive and download the latest driver for Windows 7. Install the driver to see if it resolves the issue. 2. Driver Signature Enforcement: - Since the error is related to driver signature verification, you can temporarily disable driver signature enforcement: - Restart your computer and press F8 before the Windows logo appears. - Choose "Disable Driver Signature Enforcement" from the Advanced Boot Options menu. 3. System File...
To address the issue with your HL-DT-ST DVDRAM GSA-T50N optical drive showing the error "Windows cannot verify the digital signature for the drivers required for this device. (Code 52)", consider these steps: 1. Update Drivers: - Visit the HP support website or the manufacturer's website of the DVD drive and download the latest driver for Windows 7. Install the driver to see if it resolves the issue. 2. Driver Signature Enforcement: - Since the error is related to driver signature verification, you can temporarily disable driver signature enforcement: - Restart your computer and press F8 before the Windows logo appears. - Choose "Disable Driver Signature Enforcement" from the Advanced Boot Options menu. 3. System File Checker: - Run the System File Checker tool to check for and repair any corrupted system files that might be causing the issue: - Open Command Prompt as administrator and enter the command: sfc /scannow. 4. Check Registry Settings: - Incorrect registry settings might also cause this issue. It's recommended to consult with technical support or follow advanced guides to modify registry settings related to driver signatures. 5. Update Firmware: - In some cases, updating the firmware of the optical drive can resolve compatibility issues. Check if there's a firmware update available for your DVD drive model. 6. Hardware Issues: - If the issue persists after trying the software solutions, it's possible there's a hardware problem with the DVD drive. In that case, you may need to seek professional assistance to diagnose and address any physical issues. By following these steps, you can troubleshoot and hopefully resolve the error message related to driver signature verification for your DVD drive on Windows 7.
