Rofik
- Joined
- Sep 1, 2015
- Messages
- 1
FIX broadcom wirelles radio hardware disabled error hardware and software not syncronize,,,,,,,,,
here the trick to solved error problem with broadcom wirelles utility and driver error..
i have ACER ASPIRE 3680 BUILD INbroadcom bcm43x11 and i cannot turn on radio ,, and i canot scan of wifi signal ,,
to many trial and error i get fixed ........
i see other fix use hp wireless assistant but it not work in my acer..
here the trick
1. boot your computer to linux os > like ubuntu , gparted magic in live mode or full instalation mode
2. after boot ,,goto drive OS OR C:\WINDOWS\SYSTEM32\BCMXXXX.CPL ,, OPEN WITH LEAFPAD
AND CLOSE LEAFPAD ..
3 .. RESTART AND LOG TO WINDOWS
4. ENABLE RADIO IN BROADCOM UTILITY
5 . SEE RADIO TURN ON AND WORKING AGAIN
NOTE :
BROADCOM BACK TO RADIO ERROR IF YOUR LAPTOP GET TO POWER LOST,,
TO SOLVE TURN ON HIBERNATE OR STANDBY MODE IF BATTERY LOW
,, IF YOU GET AGAIN THIS RADIO ERROR ,,TRY AGAIN STEP 1
,, AND TRY 2 ND TRICK ,TO TURN OFF WIFI VIA LINUX ,I GET WORK WITH PARTED MAGIC OS INCLUDE BROADCOM WIRELES ,,
I DONT KNOW IN LINUX RADIO GOOD NOT ERROR ..
BUT IN WINDOWS I FEEL DRIVER PROBLEMS
here the trick
NOTE :
