The user reports that their Windows 7 Dell OptiPlex 780 occasionally freezes, causing the monitor to enter power save mode, with keyboard lights remaining on. They seek advice on the cause of the issue. Respondent suggests it could be related to sleep or hibernation settings and recommends disabling them, also mentioning a possible defective power supply as a potential cause. The overall tone is technical and helpful, aiming to diagnose and resolve the freezing problem.
John Paschall
Hello, I currently have a windows 7 Dell OptiPlex 780 that occasionally and randomly freezes and the monitor goes into power save like when I shut down the computer. I know there is power to it because the lights on the keyboard are on num lock but you can't turn them off. It froze. I have to shut down holding the power button and then turning it back on and it will do it again. Anyone know what might be the problem
Thanks in advance
John
Sounds like it might be a problem with sleep mode or hibernation. Try disabling both and see if the problem goes away. A defective power supply can also produce symptoms like this.
Fixer1234
